Ivan K Posted August 27, 2021 Share Posted August 27, 2021 For those using the fancy Microair thermostats, can someone confirm whether or not it can really send temperature alerts over Wi-Fi? I am considering to replace our 5 button unit and if the alerting really works, it would make the spending justifiable for me. The other 2 ACs work off a 4 button so that will wait until I can find a cheap upgrade board one day... Thanks. Link to comment Share on other sites More sharing options...
windsorbill06 Posted August 27, 2021 Share Posted August 27, 2021 yes it can send alerts via wifi. Both high interior and low interior temperature. I only have 2 roof airs and it was an easy 'plug and play' to convert over. It's important to pick the correct thermostat. As I recall, their website walked me through it before I ordered. Great tech support too, if you need it. Link to comment Share on other sites More sharing options...
Ivan K Posted August 27, 2021 Author Share Posted August 27, 2021 6 minutes ago, windsorbill06 said: yes it can send alerts via wifi. Both high interior and low interior temperature. I only have 2 roof airs and it was an easy 'plug and play' to convert over. It's important to pick the correct thermostat. As I recall, their website walked me through it before I ordered. Great tech support too, if you need it. Awesome, thank you for sharing the actual experience Bill! Link to comment Share on other sites More sharing options...
BennieH Posted August 27, 2021 Share Posted August 27, 2021 Yes, it can send alerts via wifi. One important note, it sends the temperature it is at. In our Camelot its in the small cabinet above the door and reads the temperature up near the ceiling. I'm going to relocate it when I have a little free time. Link to comment Share on other sites More sharing options...
Ivan K Posted August 27, 2021 Author Share Posted August 27, 2021 Thank Bob, I think ours will be in a good location where the old one is, will see. Got one of the 357 type on order, seem they are not so readily available right now. Link to comment Share on other sites More sharing options...
Grampy OG Posted August 29, 2021 Share Posted August 29, 2021 On 8/27/2021 at 8:32 AM, windsorbill06 said: yes it can send alerts via wifi. Both high interior and low interior temperature. I only have 2 roof airs and it was an easy 'plug and play' to convert over. It's important to pick the correct thermostat. As I recall, their website walked me through it before I ordered. Great tech support too, if you need it. Interesting I have been using the MicroAir for several months now. In fact I have 3 installed in my coach. Where does one find the setting to send alerts? Thanks, Ken Link to comment Share on other sites More sharing options...
windsorbill06 Posted August 29, 2021 Share Posted August 29, 2021 (edited) 35 minutes ago, Grampy OG said: Interesting I have been using the MicroAir for several months now. In fact I have 3 installed in my coach. Where does one find the setting to send alerts? Thanks, Ken I do it from my phone. Open app and have window open that is showing your different zones. Then in the upper right, you see a gear symbol. Tap that and from there you can add/edit a schedule, turn schedule on/off, check for software updates. The last one listed is 'notifications'. Tap that one and it will show upper and lower limits. Set those to your liking and then tap the bottom button to turn it 'on' Edited August 29, 2021 by windsorbill06 grammar Link to comment Share on other sites More sharing options...
96 EVO Posted August 30, 2021 Share Posted August 30, 2021 Any idea if this thermostat would work with say 2 older Dometic heat pumps, and one new model? Link to comment Share on other sites More sharing options...
Ivan K Posted August 30, 2021 Author Share Posted August 30, 2021 (edited) According to microair, you would have to match versions of the control boards and pick the appropriate thermostat model. I am in the same situation, two older ones in the rear and a newer one up front. So I go with the newer front unit to control it from driver seat. When I said to match the board versions, what I meant is versions compatible with the same type of dometic thermostat. Other than the old 4 button thermostat which they don't support at all. Edited August 30, 2021 by Ivan K Link to comment Share on other sites More sharing options...
Grampy OG Posted August 30, 2021 Share Posted August 30, 2021 14 hours ago, windsorbill06 said: I do it from my phone. Open app and have window open that is showing your different zones. Then in the upper right, you see a gear symbol. Tap that and from there you can add/edit a schedule, turn schedule on/off, check for software updates. The last one listed is 'notifications'. Tap that one and it will show upper and lower limits. Set those to your liking and then tap the bottom button to turn it 'on' Awesome. I don't know how I overlooked that one. Thanks - Ken Link to comment Share on other sites More sharing options...
Bob Blackmon Posted August 31, 2021 Share Posted August 31, 2021 On 8/29/2021 at 6:37 PM, 96 EVO said: Any idea if this thermostat would work with say 2 older Dometic heat pumps, and one new model? 2008 isn't old! Do they have like thermostats? If yes they will work. Link to comment Share on other sites More sharing options...
96 EVO Posted August 31, 2021 Share Posted August 31, 2021 22 minutes ago, Bob Blackmon said: 2008 isn't old! Do they have like thermostats? If yes they will work. All 3 are controlled by the same thermostat. Link to comment Share on other sites More sharing options...
windsorbill06 Posted August 31, 2021 Share Posted August 31, 2021 1 hour ago, 96 EVO said: All 3 are controlled by the same thermostat. Ben, Their tech support is really good. They even answered a couple questions of mine on a sunday. I'd reach out to them and give them the details of your 3 units. My particular thermostat can handle up to 4 roof airs, if I had that many. www.microair.net Link to comment Share on other sites More sharing options...
96 EVO Posted August 31, 2021 Share Posted August 31, 2021 Yeah, I haven't needed to replace any of the originals 'yet', so I'm sure as long as I ordered the correct model, it would work with what I have. Was just wondering if this new magical thermostat would work with a combination of old and new boards. Link to comment Share on other sites More sharing options...
