pulsarjab Posted September 5, 2021 Posted September 5, 2021 Does anyone know where to purchase the drip rails that are on the side of the slide out? I have seen these on most of the Monaco line. Greg 2000 Diplomat
JDCrow Posted September 5, 2021 Posted September 5, 2021 9 hours ago, pulsarjab said: Ok I was going to go that route and went a different route with Talin plates and new slide toppers that went beyond tue sides of the slides. I was going to use some rubber seal to accomplish that. You have some tape on the slide (black) has it leaked?
Paul J A Posted September 6, 2021 Posted September 6, 2021 (edited) On 9/4/2021 at 8:57 PM, pulsarjab said: Does anyone know where to purchase the drip rails that are on the side of the slide out? I have seen these on most of the Monaco line. Greg 2000 Diplomat I would try; https://www.steelerubber.com/ or; https://shop.findmyrvparts.com/ Edited September 6, 2021 by Paul A. grammer
Jerry Olson Posted September 6, 2021 Posted September 6, 2021 Essential Products BL01002 Black 10' EZE RV Gutter Trim-Lok Drip Rail, Black – 1/2” Height, 25’ Length – PVC Plastic Rain Gutter
pulsarjab Posted September 7, 2021 Author Posted September 7, 2021 I have ordered the drip rail from Amazon. Thanks for all the help.
pulsarjab Posted November 3, 2021 Author Posted November 3, 2021 Drip rail installed and has solved the leak issue. Water was running down the inside of the 2 inch wide wiper rubber. Just had two days of hard rain and drip rail had running water out on the ground. Thanks for all the help. Using the 3M adhesive promoter worked great.
Guest Ray Davis Posted November 3, 2021 Posted November 3, 2021 On 11/3/2021 at 7:54 AM, pulsarjab said: Drip rail installed and has solved the leak issue. Water was running down the inside of the 2 inch wide wiper rubber. Just had two days of hard rain and drip rail had running water out on the ground. Thanks for all the help. Using the 3M adhesive promoter worked great. Great to hear the drip rail solved your problem. Pictures of where and how you used the drip rail would be a great help. I looked at the Amazon links that Jerry posted above and the second one has a big mark down in price so if anyone is thinking of buying, now might be the time. Price has been reduced 77% from $38.86 to $8.78. It says today, not sure if they really mean today only or not,, I guess you could call. Trim-Lok Drip Rail, Black – 1/2” Height, 25’ Length – PVC Plastic Rain Gutter
96 EVO Posted November 3, 2021 Posted November 3, 2021 On 9/5/2021 at 3:05 PM, JDCrow said: You have some tape on the slide (black) has it leaked? That is textured tape that helps flip the wiper seals. I have that tape on all my slides.
JDCrow Posted November 3, 2021 Posted November 3, 2021 Just now, 96 EVO said: That is textured tape that helps flip the wiper seals. I have that tape on all my slides. I need to add something to flip the wiper seals as well. Our new 5vr has pretty trick little pieces of trim stuck on
Paul J A Posted November 3, 2021 Posted November 3, 2021 (edited) It's called;"grit tape". Commonly seen and used on stair tread. https://www.forestriverforums.com/forums/f68/slide-seal-flippers-142950.html Edited November 3, 2021 by Paul A.
