Dale n Deb Posted September 21, 2021 Share Posted September 21, 2021 Our front jack leaked hydraulic fluid and wouldn't go up. We ended up removing it in order to move to our next area. We only have one jack in front on our 2008 HR Endeavor. We have been calling around without any luck. Can these be repaired or do we have to buy a new one? It is a Power Gear with the numbers 501136 on one line and under that was 08031 P 230135. We are in Cheyenne tonight and then on to Colorado. Any suggestions are welcome. Link to comment Share on other sites More sharing options...
Dr4Film Posted September 21, 2021 Share Posted September 21, 2021 You should be able to find a local hydraulic shop that will rebuild the ram and seals but if not then there is a shop in Cincinnati Ohio called Affordable Hose & Fittings that will rebuild it for you and ship it back to your location. http://www.affordablehydraulics.com/ 1 Link to comment Share on other sites More sharing options...
JDCrow Posted September 21, 2021 Share Posted September 21, 2021 Ebay https://www.ebay.com/itm/Power-Gear-359348-Lippert-501136-Hydraulic-Leveling-Jack-16-ton-/274847213526?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=711-127632-2357-0 Link to comment Share on other sites More sharing options...
RNMCBR Posted September 21, 2021 Share Posted September 21, 2021 Dale, It’s not a hard DIY job if you are inclined. Lippert’s web site has rebuild instructions and they sell kits that include seals, wear ring and a new gland for somewhat over $100. Alternatively, you can take the old seals to a hydraulic supply and they can match them up with new ones. If your rod and gland are not scored, that’s all the parts you need. I did this with one of my rear jacks and it cost less than $20 for the parts. Roy Link to comment Share on other sites More sharing options...
Dale n Deb Posted September 21, 2021 Author Share Posted September 21, 2021 Thanks for all the suggestions. It will be a matter of us being in one spot long enough to get parts. Link to comment Share on other sites More sharing options...
Paul J A Posted September 22, 2021 Share Posted September 22, 2021 Local shops that do field maintenance for construction equipment that require hydraulic cylinder service can do that repair/rebuild. Link to comment Share on other sites More sharing options...
