pbustamante41 Posted October 9, 2021 Posted October 9, 2021 (edited) I have the number for the rear air spring on my 2007 Monaco Executive (W01-358-8897). I am looking for the number for the front bags. I believe that they are the same but not sure. I am working to resolve a small leak on the right side of the rig and have replaced 4 rear bags previously and figure I might as well replace the remaining bags. Also, my aux compressor is filling all air tanks and not just the ping tank which takes about 25 minutes on average. Any suggestion on how to correct this problem is appreciated. Edited October 9, 2021 by pbustamante41
Ivylog Posted October 9, 2021 Posted October 9, 2021 (edited) Front are the same as the back… air hole may be different requiring reusing the bushing. There’s a check valve that’s supposed to stop the air from going out… not sure where. I carry one of the below as a spare. Edited October 9, 2021 by Ivylog
willbo777 Posted October 9, 2021 Posted October 9, 2021 Your number is for the front with a 3/4" hole, the number for the rear bags is W01-358-9376. You must have used a 3/4 to 1/4" bushing.
Hockeydiesel Posted October 9, 2021 Posted October 9, 2021 Contitech AS8897 - find it parts - $127 free shipping. You will need a short 1 1/4 open end wrench ( about 7" long ) for the air fitting. Also you may have to force the air fitting through the top mounting plate if you can not remove it. They can be very tight. I hope this helps. Good luck, Mike. 1
pbustamante41 Posted October 11, 2021 Author Posted October 11, 2021 Thank you for the confirmation and recommendations. What is the normal time for replacing each bag? I am being told 2 hrs per bag. This seems high but I have nothing to compare it to.
Dennis H Posted October 14, 2021 Posted October 14, 2021 My cost was about $1800 to replace all 10 air springs, about 2 months ago....Dennis
pbustamante41 Posted October 14, 2021 Author Posted October 14, 2021 3 hours ago, Dennis H said: My cost was about $1800 to replace all 10 air springs, about 2 months ago....Dennis That's a great price. My quote is $300 per bag labor only.
