Ivan K Posted January 29 Share Posted January 29 21 minutes ago, 96 EVO said: Think I may go Balance Masters. I'll be near their plant in a few days. Yeah, same thing except black and mercury balanced. I got them up front. 2 Link to comment Share on other sites More sharing options...
dl_racing427 Posted January 29 Share Posted January 29 22 hours ago, 96 EVO said: Strange 🤔! Just read a post on IRV. Guy say's he pulled into a restaurant after descending Grapevine. When he came out, he claims there were little puddles under each steer tire. Says his balancers melted from the excess brake heat! More likely the hub seal. At any rate, you should never be getting your brakes that hot. He should definitely have a truck shop check his brakes for damage. 17 hours ago, Ivan K said: Yeah, same thing except black and mercury balanced. I got them up front. Any opinion on which works better, and also how do the prices compare? Link to comment Share on other sites More sharing options...
Ivan K Posted January 29 Share Posted January 29 8 minutes ago, dl_racing427 said: Any opinion on which works better, and also how do the prices compare? IMO, they are equally good at doing the job. Balance masters are black powder coated vs galvanized. Mercury vs bearing balls. I bought balance masters first for looks, being black behind the front rim but when changing rears, I was in a hurry and could get centramatics for both rear axles overnight at a great price. Because of my proximity to their factory. Balance masters took a week to get back then and are a bit more expensive. They (BM) also have small vents for supposedly cooling the brakes, maybe so... 1 Link to comment Share on other sites More sharing options...
96 EVO Posted January 29 Share Posted January 29 Ivan, will these balancers block your view of the outer brake rotor? Link to comment Share on other sites More sharing options...
Ivan K Posted January 29 Share Posted January 29 Ben, I can only see the very outer perimeter of the rotor up front with my rims. Yeah, it pretty much blocks the view. 1 Link to comment Share on other sites More sharing options...
