gdroberson Posted May 15, 2022 Posted May 15, 2022 OK on our way to Redding ca from bullhead city first trip in this new to us MH 01 holiday Rambler 30'have 6 new ironman 255/70r 22.5 load rang h tires trying to find the chart that will give me the pressure to set the tires at had I weighed at the first scale we got to and the weight is 6660 on front ax. and 14740 on the back 21400 total can I use any chart or does it have to be Ironman cant seam to find a chart for them and how do I do the rear divide by 4 or what any help will be appreciated Thanks Gary
Ivylog Posted May 15, 2022 Posted May 15, 2022 I would look on your tires for max cold psi and weight rating dual and single. More than likely (other than Michelin) any tire chart wit the same max psi and weights will do.
gdroberson Posted May 16, 2022 Author Posted May 16, 2022 Ok thanks but the chart I have shows that I dont have enough weight to go over the 80 lb that is on the label next to the drivers seat and I am loaded full everything
Ivan K Posted May 16, 2022 Posted May 16, 2022 I would say that your H rated tires are a big overkill for that weight. Stiffer than necessary but more plies don't hurt otherwise.. Every tire has a minimum pressure, I believe mine is 85 PSI just to keep it seated on the rim. There should be a minimum listed for yours too, regardless of the inside sticker.
Mark Holt Posted May 16, 2022 Posted May 16, 2022 Go by the sticker by the driver seat for cold PSI. If that pressure is below min cold stamped on the tire raise it to min and put up with the rougher ride.
gdroberson Posted May 16, 2022 Author Posted May 16, 2022 do not find a min on cold weight but I did find a load chart for truck tires by a co. called doublecoin load inflation chart and it says that for my size tire and weight it should be 65lb front and 75 lb back but would like some other input on this dot wont to go to low and have problems thanks
dl_racing427 Posted May 16, 2022 Posted May 16, 2022 Gary, You're on the right track by getting your coach weighed. 😎 As long as the tire size is standard for your coach, with your tires being capable of carrying much more than needed, I'd stick with the recommended weights on the placard. Ride may be a little stiffer, but you'll be safe. If you do find a chart for your specific tires, then you can drop down to the chart weight recommendations.
gdroberson Posted May 17, 2022 Author Posted May 17, 2022 yes the tires are the right size this 30' coach is a little rare with the diesel eng. I can only find info for a 32 or36 ' mh I think they just cut 2' off of a 32 frame to build it
