4rickyg Posted June 7, 2022 Share Posted June 7, 2022 2005 Navigator. Was changing my clearance lights to LED's. I Accidentally touch the wires on the clearance lights above the windshield. Figured I blew a fuse. All the marker lights on the top of the coach front and back are out. But bottom marker lights headlights and tail lights are all working. Cannot find a fuse blown? Link to comment Share on other sites More sharing options...
Dr4Film Posted June 7, 2022 Share Posted June 7, 2022 Look for something that is labeled Marker lights. Also check if you have two small boxes located under the main electrical board labeled Monaco Box #1 & Monaco Box #2. If so there could be fuses in those boxes. Link to comment Share on other sites More sharing options...
4rickyg Posted June 8, 2022 Author Share Posted June 8, 2022 Do you mean in the front electrical Bay by the driver's side front tire? Link to comment Share on other sites More sharing options...
jacwjames Posted June 8, 2022 Share Posted June 8, 2022 Yes, in the front drivers side electrical bay check if you have two smaller fuse boxes labeled Monaco 1 & 2. My #1 box has a 20 amp fuse for marker lights. Link to comment Share on other sites More sharing options...
4rickyg Posted June 8, 2022 Author Share Posted June 8, 2022 Can not locate any other fuse boxes that say Monaco 1 and 2 In the front electrical day. Maybe I will look under the dash tomorrow. Link to comment Share on other sites More sharing options...
stuben Posted June 8, 2022 Share Posted June 8, 2022 Look for " parking lights" thats how mine are labeled on my 08 camelot. And it should be in the fuse bay on the drivers side front bay. Could be a relay as some coaches these lights will also blink with the flashers on . Good luck Link to comment Share on other sites More sharing options...
cbr046 Posted June 8, 2022 Share Posted June 8, 2022 The front & rear cap marker lights are operated by the ICC flasher switch on the dash, independent of the parking lights. Where the fuse is I haven't a clue, but they are on a different circuit from the parking lights. I read where the cap lights will flash on if parking lights are off by reversing polarity (prob how the ICC flasher switch is wired). With LED lights you'll lose that "on" capability. You do know that if an LED light doesn't work try reversing the leads. Chances of getting them all wrong are pretty slim. - bob Link to comment Share on other sites More sharing options...
4rickyg Posted June 8, 2022 Author Share Posted June 8, 2022 I found it. There was a fuse in the front run Bay, Had to take my time and look through every one of them. Lol. Thanks for everyone's help. But I did learn that now my LED clearance lights don't Flash with the emergency flashers. Link to comment Share on other sites More sharing options...
4rickyg Posted June 8, 2022 Author Share Posted June 8, 2022 I was wrong. Now that I have it all hooked up the LED's are working with the flashers. Link to comment Share on other sites More sharing options...
