tmw188 Posted October 23, 2023 Share Posted October 23, 2023 Has any used 303 on their roof after cleaning the roof? I’ve used the Top Side paint on a different mh but only where the paint clear and color had aged terribly. Link to comment Share on other sites More sharing options...
Tom Cherry Posted October 23, 2023 Share Posted October 23, 2023 14 minutes ago, tmw188 said: Has any used 303 on their roof after cleaning the roof? I’ve used the Top Side paint on a different mh but only where the paint clear and color had aged terribly. In the past, our “seasoned experts” were “Mop & Glo” advocates. It was applied perhaps every 3 months. The roof, at least on my Camelot, has only the base gelcoat. That is a thin sprayed on coating that is applied or sprayed into the interior of the roof mold. Typically there is a waxed (used to be hand applied when i worked at a boat factory) application or coating on the mold. Now, they are probably sprayed with a “mold release compound”. Then the mold is sprayed with a paint like gelcoating. That gelcoat is formulated to crosslink or chemically bond to the polyester resin. In the boating industry, it was applied much thicker and resembled a really heavy coating of “bumpy” latex paint. Thus, when the molded part was “popped” out, there was a thick, durable epoxy like finish….high gloss and very durable. After doing a long stint, while a manufacturing engineer, working with commercial coatings, I suspect that the gelcoat that Monaco used was formulated to cross link or “adhere like glue” with the “full body paint” and that is why it chalks and streaks. I use 303 as a headlight sealer when I restore a family member or friend’s hazed over clear lens. But, personally, it would not, IMHO, do much. Repeated mopping of “Mop n Glo” would be easier to apply and much cheaper. The previous posts about commercial coatings are correct. I often used “Top Coat” as a preservative for commercial EPDM roofs. Cheap and lasts. That’s my take….others may, probably will, have dissenting opinions…LOL Link to comment Share on other sites More sharing options...
Chargerman Posted October 23, 2023 Share Posted October 23, 2023 I am a Rustoleum Top Side proponent. I did my roof maybe 5 years ago now and it still looks perfect with absolutely zero maintenance other than washing it once a year wish soap and a soft brush. The last thing I want to be doing is getting on the roof so any regiment that requires reapplying it multiple time a year would certainly be off my list 2 Link to comment Share on other sites More sharing options...
