beemerman Posted June 29, 2022 Posted June 29, 2022 I have a 2003 Dynasty and was wondering if anyone has retrofitted the entry door with a gas shock. If you could give me some info on the shock and mounting I would appreciate the help. I'm thinking it would be a big improvement to open the door to a full 90 degrees and control the movement.
klcdenver Posted June 29, 2022 Posted June 29, 2022 Go to this link it will have all the info you need. I have done it to 2 motor homes and works well. https://www.irv2.com/forums/f258/gas-door-prop-installed-241214.html
azcamel Posted June 29, 2022 Posted June 29, 2022 I did this about a year ago following the threads on this site! What a huge improvement! No issues to date. One of the better mods to do... IMHO
Tom Wallis Posted June 29, 2022 Posted June 29, 2022 I did the door on my Monarch about 4 years ago. I just figured it out on my own. My door is slightly different but it's the same principle. I agree with Cory, it' a huge improvement. I had thought about doing a video on it but I never got around to it. Those darn round-to-its.
timaz996 Posted June 29, 2022 Posted June 29, 2022 AS far as I know everyone is happy with this upgrade. No more banging door when it opens to far. Here are some pictures for you to use. Tim
SteveC Posted June 29, 2022 Posted June 29, 2022 3 hours ago, klcdenver said: Go to this link it will have all the info you need. I have done it to 2 motor homes and works well. https://www.irv2.com/forums/f258/gas-door-prop-installed-241214.html 100% on the money. I did this to my 2000 Signature and it is one of the best upgrade mods yet. I agree with the author in the link regarding measure and check before drilling.
Steve P Posted June 29, 2022 Posted June 29, 2022 I have looked at the post and the PDF file on how to install this a dozen times. I can't seem to make it work in my head. Could someone post a picture or 2 at different angles of the door open and the gas strut extended? Without the original door swing arm in place, it seems like the door could keep swinging, and if pushed by the wind, compress the gas strut, and go as far as hitting the mirror.
hitechpete Posted June 30, 2022 Posted June 30, 2022 16 hours ago, Steve P said: I have looked at the post and the PDF file on how to install this a dozen times. I can't seem to make it work in my head. Could someone post a picture or 2 at different angles of the door open and the gas strut extended? Without the original door swing arm in place, it seems like the door could keep swinging, and if pushed by the wind, compress the gas strut, and go as far as hitting the mirror. I believe that the strut will be fully extended when the door is at 90 degrees, and that internal strut pressure will prevent the wind closing the door.
beemerman Posted June 30, 2022 Author Posted June 30, 2022 Thanks for the information, looks like just what I was wanting to do. Has to be a big improvment.
Steve P Posted June 30, 2022 Posted June 30, 2022 The key question (in my mind): The original door swing arm is acting as the stop, not the gas strut. What would happen if one were to remove the swing arm... would the door keep going and compress the gas strut, perhaps swinging open until it hit the mirror? (I want very much to get rid of the defect prone swing arm! It rattles, needs adjustment, eventually breaks -- well mine lasted 12 years, but it is history).
timaz996 Posted July 1, 2022 Posted July 1, 2022 Nothing will happen. The strut will stop it just a the scissor arm does now. I removed mine when I installed the strut. Tim
