Lee Smith Posted June 30, 2022 Share Posted June 30, 2022 I am having the Onan generator 1,000-hour service done. How long do you think the original water pump will last? My coach is a 2004 Signature, and I don't know how age affects the internal parts in a water pump such as seals, etc. The generator has only 1,250 hours but I am do not have any records as to when the generator was serviced so I am having the 1,000-hour service done as preventative maintenance. Please share your information on replacing the water pump. Thank you. Link to comment Share on other sites More sharing options...
Ivan K Posted June 30, 2022 Share Posted June 30, 2022 We are at 4k hours with original pump, just for reference but it still could be a good idea if you pay for labor. 1 Link to comment Share on other sites More sharing options...
Lee Smith Posted July 1, 2022 Author Share Posted July 1, 2022 Okay I am now convinced a water pump is likely not needed. My general rule on my previously owned pick-up trucks was not to even consider a water pump until after 70,000 miles and even then, I waited for a failure to do a replacement. Of course, in my Signature that would be a mistake to wait for failure but based on the information I have received here and other places, I should not be anywhere near ready for a water pump replacement at 1,250 hours. No one has told me that the age of 18 years old is an issue. I am very thankful for the help I received on this great forum. Please see my fuel injector post for a very similar follow-up. Link to comment Share on other sites More sharing options...
96 EVO Posted July 1, 2022 Share Posted July 1, 2022 23 hours ago, Ivan K said: We are at 4k hours with original pump, just for reference but it still could be a good idea if you pay for labor. Lot's of use 👍! I'm at 356hrs. 1 Link to comment Share on other sites More sharing options...
Hypoxia Posted July 2, 2022 Share Posted July 2, 2022 If you are in there already I would replace it on principal since it is quite a job to get to it. Age is always an issue with anything that has a seal, they do not improve with age. It's the same principal as changing the water pump whenever changing a timing belt on a car, you don't want to have to go back in there when you were already there. 1 Link to comment Share on other sites More sharing options...
