Hancoman Posted July 15, 2022 Share Posted July 15, 2022 Hello all. On our last trip we suddenly get no water from the hot side of our kitchen faucet. Changed the cartridge today, still no water from the hot side. All other faucets have water from the hot side bathroom, bedroom and shower. Any Ideas ? Link to comment Share on other sites More sharing options...
Steve Maurer Posted July 15, 2022 Share Posted July 15, 2022 Bad faucet? Link to comment Share on other sites More sharing options...
vito.a Posted July 15, 2022 Share Posted July 15, 2022 Check the Manablock in the basement. Its the blue plastic water distribution manifold. It has on/off valves for each faucet. Is your kitchen sink in a slideout? If so then you'll need to check the plumbing from coach to slide. Link to comment Share on other sites More sharing options...
Hancoman Posted July 15, 2022 Author Share Posted July 15, 2022 Vito. Would that be in the bay with the aqua hot. Yes sink is in a slide out. I will check when I go back out Thanks Tom Link to comment Share on other sites More sharing options...
jacwjames Posted July 15, 2022 Share Posted July 15, 2022 Water filter is only for cold water side. Do you get cold water through the faucet? You might have to take the faucet apart and check for blockage. When was the last time you flushed you hot water heater, over time I get a pretty good build up of sediment, not likely but it might be possible to get a slug of this to your faucets. Link to comment Share on other sites More sharing options...
Hancoman Posted July 15, 2022 Author Share Posted July 15, 2022 Cold water works . When you turn the faucet to hot it stops. I will have to unhook the hot and see if I have flow. I did take the faucet apart and put in a new cartridge. Link to comment Share on other sites More sharing options...
windsorbill06 Posted July 15, 2022 Share Posted July 15, 2022 4 hours ago, Hancoman said: Cold water works . When you turn the faucet to hot it stops. I will have to unhook the hot and see if I have flow. I did take the faucet apart and put in a new cartridge. Did you put the new cartridge in before or after this issue? Depending on model, cartridge can go in reversed and will cause your problem, or the hot/cold could be reversed. Link to comment Share on other sites More sharing options...
Hancoman Posted July 16, 2022 Author Share Posted July 16, 2022 Cartridge after no hot water Link to comment Share on other sites More sharing options...
gofastnow Posted July 18, 2022 Share Posted July 18, 2022 Tom, probably not your problem, but I had a similar situation after closing and reopening the shutoff valve at the sink. What I found was the rubber seal had swollen in diameter and had pulled of the stem of the valve in the closed position, thus limiting flow. My MH has Qest valves and the seal is pressed onto the stem. go figure. Link to comment Share on other sites More sharing options...
Hancoman Posted July 23, 2022 Author Share Posted July 23, 2022 Finally got around to working on the no hot water problem, Vito you were correct somehow the kitchen water had been turned off on the Manablock in the basement. Also finished work on the kitchen drain in the slide out where the flex tube broke. Hard work for a fat old man that doesn’t bend very well anymore, next time I will pay to have it done Link to comment Share on other sites More sharing options...
