olywrestle Posted September 23, 2023 Share Posted September 23, 2023 Any recommendations on the grease for the slack adjuster? My manual just says clay-based lubricant for them. No idea what was last used... Link to comment Share on other sites More sharing options...
96 EVO Posted September 23, 2023 Share Posted September 23, 2023 Greased mine just yesterday. I've been using Lucas Red n Tacky grease for several years. https://www.lucasoil.com/product/red-n-tacky-grease/ 1 Link to comment Share on other sites More sharing options...
olywrestle Posted September 23, 2023 Share Posted September 23, 2023 That's lithium based, my guide says Clay based. Has lithium progressed since 2006 that it could be used instead of the clay based? Link to comment Share on other sites More sharing options...
96 EVO Posted September 23, 2023 Share Posted September 23, 2023 11 minutes ago, olywrestle said: That's lithium based, my guide says Clay based. Has lithium progressed since 2006 that it could be used instead of the clay based? Ask the guy behind the parts counter for 'Clay' based grease! He'll look at you like you have two heads 😁! 2 Link to comment Share on other sites More sharing options...
Ivan K Posted September 23, 2023 Share Posted September 23, 2023 My Meritor brakes also call for clay base and I used their brand grease, pretty pricey, there are probably cheaper alternatives 1 Link to comment Share on other sites More sharing options...
96 EVO Posted September 23, 2023 Share Posted September 23, 2023 Ahh. You found the elusive 'clay based grease' 👍! Link to comment Share on other sites More sharing options...
Ivan K Posted September 23, 2023 Share Posted September 23, 2023 I don't remember if these specifications bring any alternative results, the meritor tube is like $50 but it does all 4 corners and I spent too much on hardware to take a chance 1 Link to comment Share on other sites More sharing options...
96 EVO Posted September 23, 2023 Share Posted September 23, 2023 I only have disc's on the front, and the calipers are sealed ☹️! Link to comment Share on other sites More sharing options...
Frank McElroy Posted September 23, 2023 Share Posted September 23, 2023 2 hours ago, olywrestle said: Any recommendations on the grease for the slack adjuster? My manual just says clay-based lubricant for them. No idea what was last used... Interesting that your manual call for only a clay based grease. The Bendix/Spicer slack adjusters on my coach only say not to use a grease containing Moly-disulfide. I use a synthetic lithium grease for all grease fittings on my coach. Link to comment Share on other sites More sharing options...
olywrestle Posted September 23, 2023 Share Posted September 23, 2023 Thanks all for the replies. I apparently have conflicting info in the guide. One page says NLGI #2 Lithium The other page has CBL, which in the manuals decoder is stands for Clay Based So now I am even more conflicted on which direction to go! Link to comment Share on other sites More sharing options...
96 EVO Posted September 23, 2023 Share Posted September 23, 2023 1 hour ago, Ivan K said: I don't remember if these specifications bring any alternative results, the meritor tube is like $50 but it does all 4 corners and I spent too much on hardware to take a chance Well, use it sparingly! A team of sherpa's must have climbed high in the Himalaya's to fill that tube for ya 😂! 1 1 Link to comment Share on other sites More sharing options...
