firefly4205 Posted May 17, 2020 Share Posted May 17, 2020 My alternator on my 2002 Windsor is over charging the batteries. I have been unable to find a new replacement alternator. Does anyone know if there is a new replacement model for this Leece Neville 4884JB alternator or has anyone had one like this rebuilt? Firefly4205 2002 Windsor Link to comment Share on other sites More sharing options...
Mel S - '96 Safari Posted May 17, 2020 Share Posted May 17, 2020 Firefly See: https://www.google.com/search?sxsrf=ALeKk029-6bAbgZXhJBim-JWmfwx5cuDUw%3A1589735917416&source=hp&ei=7XHBXsnuFsiutQaE_r_QDg&q=Leece+Neville+4884JB&oq=Leece+Neville+4884JB&gs_lcp=CgZwc3ktYWIQDDICCABQkgpYkgpg9CxoAHAAeACAAVuIAVuSAQExmAEAoAECoAEBqgEHZ3dzLXdpeg&sclient=psy-ab&ved=0ahUKEwiJmZHls7vpAhVIV80KHQT_D-oQ4dUDCAg HOWEVER, because the compatibly of a new replacement alternator is often problematic....I suggest you have your original alternator rebuilt. ....(to find a rebuilder Google "alternator rebuild shop near me". Link to comment Share on other sites More sharing options...
jacwjames Posted May 17, 2020 Share Posted May 17, 2020 The original alternator on my 2002 Windsor is A0012824LC, was yours previously changed? They are available. https://www.amazon.com/s?k=A0012824LC&ref=nb_sb_noss My alternator quit working ~2014, I took it off and had it rebuild for ~$185. Link to comment Share on other sites More sharing options...
Dr4Film Posted May 19, 2020 Share Posted May 19, 2020 My 2002 Windsor came with a 160 amp Leece-Neville Alternator model A0012824LC. I had that rebuilt a few times over the years. Then a local friend had a brand new spare 200 amp Leece-Neville Alternator model 4884JB which I bought as a spare. Back in 2015 when in Alaska my 160 amp alternator failed once again. I had the 200 amp installed and took the 160 amp unit to the local shop and had them rebuild it to a 200 amp one. Cost me about $400. Back when having the 160 rebuilt it was generally between $160 - $180. Those two models are interchangeable. Link to comment Share on other sites More sharing options...
jacwjames Posted May 19, 2020 Share Posted May 19, 2020 Richard, thanks>> good information to know I did a search and found the Prestolite data page on the alternator and then did a search using A0014884JB on Google shopping and had numerous hits, one of the best prices I found was here https://www.sears.com/rareelectrical-new-200a-alternator-international-with-duvac-zln4884jb/p-SPM8253389227?sid=IDx20141117x00001xlpla The price range was from $1150 to $300 so it pays to shop. Link to comment Share on other sites More sharing options...
firefly4205 Posted May 21, 2020 Author Share Posted May 21, 2020 Thanks to everyone who replied to my question about the Leece-Neville 4884JB alternator. This is the original alternator and I bought the coach new so it has not been changed. I ended up speaking with Jim @ AJ Electric and he was very helpful and told me several different test to run prior to ordering a new unit and I am in the process of doing those tests now. He is a very nice fellow and I would recommend this company if you develop electrical problems. I am sorry I did not respond sooner but for some reason I have not been receiving my e-mails correctly. Link to comment Share on other sites More sharing options...
Hotrod Posted May 22, 2020 Share Posted May 22, 2020 Are both chassis and house overcharging? If so, change the regulator on the alternator. Only a 20$ part. That means if you diy it costs you 20$. If only the chassis or only the house is over charging , it’s the solid state isolator . You can get them on amazon. Link to comment Share on other sites More sharing options...
veraken Posted May 23, 2020 Share Posted May 23, 2020 Recently replaced my alternator. I found the best price at Quality Power. I decided to replace my 160 amp Leece Neville with a 200 amp Delco Remy 28SI. The install was fairly simple except on the DR you don't connect the excite wire since it is self exciting. I had my old LN rebuilt and carry it as a spare. https://www.qualitypowerauto.com/category_139/RV-Alternators.htm Link to comment Share on other sites More sharing options...
dl_racing427 Posted May 23, 2020 Share Posted May 23, 2020 On 5/22/2020 at 7:26 AM, Hotrod said: Are both chassis and house overcharging? If so, change the regulator on the alternator. Only a 20$ part. That means if you diy it costs you 20$. If only the chassis or only the house is over charging , it’s the solid state isolator . You can get them on amazon. Careful. Some regulators also retain the brushes, which can be a real bear to get back into position when reinstalling the new regulator. You have to use steel pins to retain the brushes, and unless you have the correct size, it's quite fiddly. Link to comment Share on other sites More sharing options...
