Ted Carbonaro Posted February 23 Share Posted February 23 I’m having intermittent issues with my keyless entry pad/system. I have the TriMark e-ASK and for the past two days it has been emitting the chirp sound intermittently on its own. Yesterday it was inoperable for a while then returned to normal operation. Today, other than a few intermittent chirps, it appears to be dead. I started inspecting the wiring and such yesterday, then when it started working normal, I figured it was repaired from something I moved or touched. Has anyone had similar symptoms and a solution? I suspect low voltage or a failed part of the system. BTW; I did not get a remote e-FOB with the secondhand coach. Link to comment Share on other sites More sharing options...
Big Dave Posted February 23 Share Posted February 23 I don't have this type of System on my Coach. But if it is chirping it needs the battery to be replaced. You might be able to google your model you have and get a video or instruction on how to replace it. Link to comment Share on other sites More sharing options...
Happycarz Posted February 23 Share Posted February 23 (edited) Ted, have you found the TriMark box behind the upper part of the dash? Unplug it and wait for two minutes to plug it back in. See if that works for you. Just the power wire pair is what to unplug. Edited February 23 by Happycarz Link to comment Share on other sites More sharing options...
Ted Carbonaro Posted February 23 Author Share Posted February 23 Harry I’m going on a search for it now. Will report back. Link to comment Share on other sites More sharing options...
Bill R Posted February 24 Share Posted February 24 @Ted Carbonaro if it is not where @Happycarzsuggests, mine is under the passenger side cup holder/storage compartment which is just on the inside of the outside keypad. Link to comment Share on other sites More sharing options...
Ted Carbonaro Posted February 24 Author Share Posted February 24 Thanks Bill. That is where I located mine. I have power to the control module and power from the module to the keyless pad but no operation. I’ll be calling TriMark tomorrow hopefully to get some tech assistance. Link to comment Share on other sites More sharing options...
myrontruex Posted February 24 Share Posted February 24 If you have cabinet drawers near your feet upfront, pull the drawers out and look in the back. I was not aware of any battery inside the device on mine and we have had ours since 2008 new. IF you were tugging and pulling on cables you may have exercised the power plug just enough to clean up the voltage as you hinted at. Link to comment Share on other sites More sharing options...
96 EVO Posted February 24 Share Posted February 24 12 hours ago, Ted Carbonaro said: Thanks Bill. That is where I located mine. I have power to the control module and power from the module to the keyless pad but no operation. I’ll be calling TriMark tomorrow hopefully to get some tech assistance. Does your '06 have the doorbell button? Link to comment Share on other sites More sharing options...
Ted Carbonaro Posted February 24 Author Share Posted February 24 Not that I know of. Link to comment Share on other sites More sharing options...
Ted Carbonaro Posted March 10 Author Share Posted March 10 I resolved the issue by replacing the keyless keypad. It was available from Northwest RV Supply for $139. TriMark does offer technical advice and according to Kevin I was very fortunate to find a new replacement keypad as they are no longer offered thu TriMark. Link to comment Share on other sites More sharing options...
