Romeo84 Posted March 30, 2023 Share Posted March 30, 2023 Nice! Congrats on saving about $3000!! 1 Link to comment Share on other sites More sharing options...
jacwjames Posted March 30, 2023 Share Posted March 30, 2023 Glad you got it fixed. How hard was it to get to the sensor and get it out??? Link to comment Share on other sites More sharing options...
Groovy Posted March 30, 2023 Author Share Posted March 30, 2023 1 hour ago, jacwjames said: Glad you got it fixed. How hard was it to get to the sensor and get it out??? Easy, maybe 3 minutes. Took passenger side engine bay 'vents' off and had full access. 11/16" wrench is all that was required to remove sensor. 1 Link to comment Share on other sites More sharing options...
Just Jim Posted April 18, 2023 Share Posted April 18, 2023 I have a new to me 2003 Executive with the ISM 500. I have somehow gotten a hole in the fuel filter. Searching for the filter now, but curious how to prime it after I switch them out? Link to comment Share on other sites More sharing options...
Romeo84 Posted April 18, 2023 Share Posted April 18, 2023 Yikes which filter. If it's the ravor plastic prefilter those are getting tricky to source. Your unit should have a electric primer at the rear. With the Key on and depressing the valve hold the button till full till fuel comes out. There pretty ez Link to comment Share on other sites More sharing options...
Groovy Posted April 18, 2023 Author Share Posted April 18, 2023 Hi Jim Secondary fuel filter on ISM should be tight against the engine on passenger side. Access from underneath. If you have the factory racor system and it works, ignition key on and press the prime button on the primary fuel / water setup at rear of engine. That should prime the filter. May have to do it a couple of times. Link to comment Share on other sites More sharing options...
Just Jim Posted April 18, 2023 Share Posted April 18, 2023 My old 95 Dynasty has that racor water/air primer... it appears this one has had it removed. Any idea if there is a manuel primer on the engine somewhere? Perhaps they have installed the FASS system? I have no idea what that even looks like to know if I have it or not... Fun, Fun, Fun... nothing like getting up to speed on a new coach Link to comment Share on other sites More sharing options...
Just Jim Posted April 18, 2023 Share Posted April 18, 2023 It is the primary filter.... its right behind the mud flap. Didn't leak bad but enough for it to suck air. I've the new one on.... cross your fingers that it will prime and start. Link to comment Share on other sites More sharing options...
Just Jim Posted April 18, 2023 Share Posted April 18, 2023 thanks for the help guys. switched it several times and the 3rd time I tried to start it, she went. I am just glad I learned this lessen in my driveway. I think I'm leaving the tag axle down from now on. There is not that much slope on my drive, but apparently enough with the tag up to squash that filter. Link to comment Share on other sites More sharing options...
Just Jim Posted April 18, 2023 Share Posted April 18, 2023 2 hours ago, Romeo84 said: Yikes which filter. If it's the ravor plastic prefilter those are getting tricky to source. Your unit should have a electric primer at the rear. With the Key on and depressing the valve hold the button till full till fuel comes out. There pretty ez I found a source for those pre-filters down in Texas. Let me know if you need them and I'll figure out their name. However, you can just wash them out and reinstall if they are not to bad. That is what I've done the last few times. I got a bad case of algae and had to replace that one, but I stay on top of that now and have not had any issues just reusing the same one each time. I obviously replace the second filter every time. 1 Link to comment Share on other sites More sharing options...
RedSectorA Posted April 18, 2023 Share Posted April 18, 2023 30 minutes ago, Just Jim said: I found a source for those pre-filters down in Texas. Let me know if you need them and I'll figure out their name. However, you can just wash them out and reinstall if they are not to bad. That is what I've done the last few times. I got a bad case of algae and had to replace that one, but I stay on top of that now and have not had any issues just reusing the same one each time. I obviously replace the second filter every time. If you don't mind I'd like to know, could not find them so far. There are so many cleaning that filter can take. Thanks, Link to comment Share on other sites More sharing options...
Just Jim Posted April 19, 2023 Share Posted April 19, 2023 6 hours ago, RedSectorA said: If you don't mind I'd like to know, could not find them so far. There are so many cleaning that filter can take. Thanks, It is a Racor 300200 filter. I have not ordered from them in a while, but this is who had them in stock. M&D Distributors 7902 FM 1960 Bypass Rd. W. Humble, TX 77338 Email: ecominfo@mddistributors.com Toll Free: (800) 658-9333 1 Link to comment Share on other sites More sharing options...
