LaPalma 34PDD Posted March 28, 2023 Share Posted March 28, 2023 Hi, I have a 2006 Monaco LaPalma 34PDD and am trying to figure out what electrical component was installed in the passenger side storage compartment above the dash. It has 2 6.0 sized electrical cables, one red and one white. They run along the inside of the wall so I am assuming they were factory? Any ideas? Link to comment Share on other sites More sharing options...
Tom Wallis Posted March 28, 2023 Share Posted March 28, 2023 Mine had the satellite receiver and some other TV equipment in that same compartment. Link to comment Share on other sites More sharing options...
JohnC3 Posted March 28, 2023 Share Posted March 28, 2023 Mine has an AV amp and cd player there. Based on the other wire( it looks like the wire I had going to my roof FM antenna), It might be some sort of radio? Link to comment Share on other sites More sharing options...
LaPalma 34PDD Posted March 29, 2023 Author Share Posted March 29, 2023 Thanks John, Link to comment Share on other sites More sharing options...
Dave Pumphrey Posted March 29, 2023 Share Posted March 29, 2023 Are you sure they are 6 Gauge? 6 Gauge would be close to the size of a battery cable on a car, they don't look that heavy. I don't know of any audio or video items that would have that heavy of wire. Is there power present? It would likely be 12 volt. Link to comment Share on other sites More sharing options...
MyronTruex Posted March 29, 2023 Share Posted March 29, 2023 Any chance it could have been some sort of small inverter/ Link to comment Share on other sites More sharing options...
bigbhb Posted March 30, 2023 Share Posted March 30, 2023 2 hours ago, myrontruex said: Any chance it could have been some sort of small inverter/ I have a cd player in mine. Link to comment Share on other sites More sharing options...
bigbhb Posted March 30, 2023 Share Posted March 30, 2023 Myron, watch that bigbhb guy! Lol Link to comment Share on other sites More sharing options...
LaPalma 34PDD Posted March 30, 2023 Author Share Posted March 30, 2023 Hi Dave, Yeah pretty sure it is 6 gauge, that is what it says on the cable. They are big for an electronic gadget but maybe an inverter was here? I have the surround sound amp and the CD player mounted in the opposite cabinet and looks like this is how it came from the factory. What was missing was a receiver for the old Winegard that was mounted on the roof but I dont think the cabling would have been this big for this, but it was 2006 so not sure if they used this size cable. I appreciate the input from you all. Link to comment Share on other sites More sharing options...
Larry Laursen Posted March 30, 2023 Share Posted March 30, 2023 I think some are confusing 6 gauge with 006 wire. The 00's such as 002, 004, etc are the large cables used on heavy loads and batteries. 6, 8, 10, 12 gauge are house wires and go up to 26 for electronics. The IEEE numbering is confussing😊 Link to comment Share on other sites More sharing options...
Dave Pumphrey Posted March 30, 2023 Share Posted March 30, 2023 Did you check to see if there is power there? I would use a non contact voltage detector to check for 110 volts, then a voltmeter set to over 120 volts AC, ( probably the 250 scale on most meters). Then set the meter to DC volts, to see if it is 12-13 volts. Let us know if you find the answer! Link to comment Share on other sites More sharing options...
