RedSectorA Posted June 3, 2023 Share Posted June 3, 2023 (edited) Anybody knows the part number for an air dryer on a 2000 Holiday Rambler Navigator? Tried the Bendix 109994, although it's the same size the screw on opening is different. I sent pictures of mine alongside the Bendix for comparison. Thx Edited June 3, 2023 by RedSectorA Link to comment Share on other sites More sharing options...
RedSectorA Posted June 3, 2023 Author Share Posted June 3, 2023 Looks like this one but unsure if it's the right replacement. https://www.haldex.com/en/na/air-dryerair-line/air-dryers/haldex-newremanufactured/pure-air-plus-service-kits/dq6036/ Link to comment Share on other sites More sharing options...
96 EVO Posted June 3, 2023 Share Posted June 3, 2023 The filter in the box looks like it is for a Meritor / Wabco System Saver 1200 dryer. Link to comment Share on other sites More sharing options...
tmw188 Posted June 3, 2023 Share Posted June 3, 2023 (edited) This is mine on a 2002 Windsor 40 8 bag chassis. Edited June 3, 2023 by tmw188 Link to comment Share on other sites More sharing options...
Tom Cherry Posted June 3, 2023 Share Posted June 3, 2023 GO TO THIS THREAD OR TOPIC. The info as well as specs and such are in there. Very informative also. There is a complete discussion of the various lengths and sizes as well as the advantages of a coalescing filter…. If you need MORE….there is. Put WABCO into the search and then click on topics. Also Parts List has complete info. Download it…. Link to comment Share on other sites More sharing options...
veraken Posted June 5, 2023 Share Posted June 5, 2023 Here's a video which explains the differences in spin on air dryer cartridges. Bottom line, you need to know what system you have. 1 Link to comment Share on other sites More sharing options...
Solution RedSectorA Posted June 13, 2023 Author Solution Share Posted June 13, 2023 Thanks guys for your help. I found the cartridge, it's a Haldex DQ6036. I personally bought a Automann 170.DQ6036 as a cheaper alternative. I figured I would post for posterity. https://www.haldex.com/en/na/air-dryerair-line/air-dryers/haldex-newremanufactured/pure-air-plus-service-kits/dq6036/ Link to comment Share on other sites More sharing options...
96 EVO Posted June 13, 2023 Share Posted June 13, 2023 Drain your air tanks frequently checking for moisture after the switch! From experience, I've found knockoff dryer filters can be hit or miss, whether they actually do the job! Link to comment Share on other sites More sharing options...
RedSectorA Posted June 13, 2023 Author Share Posted June 13, 2023 Just now, 96 EVO said: Drain your air tanks frequently checking for moisture after the switch! From experience, I've found knockoff dryer filters can be hit or miss, whether they actually do the job! Good to know thanks, I already planned on purging my tanks regularly so that shouldn't be an issue. 1 Link to comment Share on other sites More sharing options...
Ron Shantos Posted June 10 Share Posted June 10 I have a Wabco System Saver 1200 Air Dryer. The current replacement cartridge is a R950011. There are 2 replacement cartridges. Wabco 4324209232 & 4329012482 available from Wabco. The 4329012482 ALSO REMOVES OIL also. So, which is the best Wabco choice to use as a replacement for the R950011? Of interest is that Wabco says if you use the cartridge that removes oil you must continue to use that part number in the future other wise it will dry the system O Rings out. What is the recommended Wabco replacement for the R950011 Air Dryer Cartridge? Ron Link to comment Share on other sites More sharing options...
96 EVO Posted June 10 Share Posted June 10 Hold a paper towel under your purge valve when your compressor unloads. No oil on the paper towel, buy the standard filter. 1 Link to comment Share on other sites More sharing options...
Ron Shantos Posted June 10 Share Posted June 10 Thanks for the quick response. That makes sense. Will do, and once again COMMOM SENSE!! Ron Link to comment Share on other sites More sharing options...
