Groovy Posted June 19, 2023 Share Posted June 19, 2023 Hi folks As I work my way through the surprises I have found a bundle of 7 wires tucked under the navigation unit as I was removing it. 3 red, 2 green a yellow and a white. One of the red wires is of fairly substantial gauge. They look like they have been there always, and writing on the wires matches all other in the coach so assuming factory installed. Curious if they may run to the back? Can't seem to locate in engine bay. Any thoughts would be appreciated. Link to comment Share on other sites More sharing options...
timaz996 Posted June 19, 2023 Share Posted June 19, 2023 I don’t know where they run to but I’m sure they are wires for some option that your coach was not ordered with. Being that it is a signature. I would guess you wouldn’t fine too many of those. 1 Link to comment Share on other sites More sharing options...
Flyinhy Posted June 20, 2023 Share Posted June 20, 2023 Only things in that area that I can think of would be Security system , trip tek , surround sound system If you can trace the wires to a plug that has a number on it.... I'm sure that will pin point what option was not installed or removed. 1 Link to comment Share on other sites More sharing options...
Ivan K Posted June 20, 2023 Share Posted June 20, 2023 I have pulled pounds of cable bundles between the old head unit, cd changer and cd based gps unit from our 2000. The bundles were unnecessary long and coiled behind the center console just like in your picture. Link to comment Share on other sites More sharing options...
