BradHend Posted July 22, 2023 Share Posted July 22, 2023 (edited) While undergoing repairs on the coach I hit this device pretty hard with the manifold when it let go. It’s in terrible condition to start with. What exactly is it for? Cummins Quickserve just specifically shows a “plug” being there. Monaco installed device? Temp sensor? Anyone care to inform me what it’s purpose is and where I might find another? Thanks. Did some more digging. It’s the oil pressure sending unit. $152 for a new one. Thanks anyways. Edited July 22, 2023 by BradHend Link to comment Share on other sites More sharing options...
Old Dog Posted July 22, 2023 Share Posted July 22, 2023 Looks like an oil pressure sending unit most likely for a oil psi guarge and/or the ecm. 1 Link to comment Share on other sites More sharing options...
jacwjames Posted July 22, 2023 Share Posted July 22, 2023 YIKES, $152 I have a 8.3 ISC, either of these oil sender listed are $50-60 1 Oil Pressure Sending Unit.pdf Link to comment Share on other sites More sharing options...
Solution vito.a Posted July 23, 2023 Solution Share Posted July 23, 2023 Most of these coaches use a VDO 360 023 oil pressure sending unit. It's a 0-180ohm dual terminal sending unit. You can pick one up on eBay for $34. 1 Link to comment Share on other sites More sharing options...
rvtips Posted July 23, 2023 Share Posted July 23, 2023 How long has that filter been on?? 1 Link to comment Share on other sites More sharing options...
BradHend Posted July 23, 2023 Author Share Posted July 23, 2023 @rvtips Not long at all. It looks that way due to soot from a nasty manifold leak. Thanks everyone for chiming in and getting me a part number. Ordered from Summit Racing. 1 Link to comment Share on other sites More sharing options...
Agpopp Posted July 24, 2023 Share Posted July 24, 2023 (edited) Brad, I was going to chime I'm but a little late. My Neptune just lost the oil pressure gauge coming home last week. The VDO 360023 is in fact the right one as I just finished installing mine today that came from Summit Racing earlier in the week. I took a chance it was the right one and it threaded right in. And I might add, this sender is only for the gauge and the Ecm has its own....the dash and engine do not communicate, same as the dual feed coolant temp sender on the top of the engine, it is gauge connected only. Edited July 24, 2023 by Agpopp 1 Link to comment Share on other sites More sharing options...
BradHend Posted July 24, 2023 Author Share Posted July 24, 2023 (edited) @Agpopp Thanks for the confirmation. Greatly appreciated. Puts my mind at ease as I was a little concerned I may have purchased the wrong wrong as there were different resistance values on that website. Forgot to mention how much I love to see new parts on the old stuff. My exhaust side of the engine is gonna look mint when I’m done. New manifold, Reman Turbo, reman EGR valve, all new oil and coolant lines for the turbo and exhaust recycling plumbing, all new coolant lines to the radiator etc etc. Oh and let’s not forget that puny little pipe with the little corrugated section that goes from the EGR valve to the EGR cooler that cost me $600 f’ing dollars. Couldn’t find used, that was the cheapest I could find. Plus import fees. 🤬 🤑🤑 Edited July 24, 2023 by BradHend Link to comment Share on other sites More sharing options...
dl_racing427 Posted July 26, 2023 Share Posted July 26, 2023 On 7/24/2023 at 4:43 PM, BradHend said: @Agpopp Thanks for the confirmation. Greatly appreciated. Puts my mind at ease as I was a little concerned I may have purchased the wrong wrong as there were different resistance values on that website. Forgot to mention how much I love to see new parts on the old stuff. My exhaust side of the engine is gonna look mint when I’m done. New manifold, Reman Turbo, reman EGR valve, all new oil and coolant lines for the turbo and exhaust recycling plumbing, all new coolant lines to the radiator etc etc. Oh and let’s not forget that puny little pipe with the little corrugated section that goes from the EGR valve to the EGR cooler that cost me $600 f’ing dollars. Couldn’t find used, that was the cheapest I could find. Plus import fees. 🤬 🤑🤑 Heck, I'd have just deleted the EGR. Your engine will run cooler and more efficiently, your oil will stay cleaner, and cylinder and ring wear will be reduced without that mess of a system. Link to comment Share on other sites More sharing options...
BradHend Posted July 26, 2023 Author Share Posted July 26, 2023 @dl_racing427 I called around to several shops just for that, nobody would touch it. The reason they claim was the year. I think they said 2007 and newer they could, but not on my ‘05. I looked fairly hard into this. Would have been able to get a standard exhaust manifold as well. 1 Link to comment Share on other sites More sharing options...
Agpopp Posted July 26, 2023 Share Posted July 26, 2023 6 hours ago, dl_racing427 said: Heck, I'd have just deleted the EGR. Your engine will run cooler and more efficiently, your oil will stay cleaner, and cylinder and ring wear will be reduced without that mess of a system. I've researched it for mine and there is nothing available to perform the delete as far is can tell. The egr system on these engines was installed earlier than the pickup versions, and additionally, these are specific ECMs that no one has tuned. These are rear gear; industrial/bus versions and no such parts are available. But, I hope I can be proven wrong. 2 Link to comment Share on other sites More sharing options...
Agpopp Posted July 27, 2023 Share Posted July 27, 2023 Hey Brad, look at the pic of my alternator above and have a look. I think I'm missing some wires? Did you take any of yours before you took things apart? Seems there should be wires on those 3 posts. Seems to work fine but it got me thinking. Link to comment Share on other sites More sharing options...
BradHend Posted July 27, 2023 Author Share Posted July 27, 2023 @Agpopp Unless we are both missing wires there, I think it’s safe to say you’re good. You have spares floating around back there that should be landed somewhere or just making sure? Link to comment Share on other sites More sharing options...
Agpopp Posted July 27, 2023 Share Posted July 27, 2023 Thanks. No spares, but couldn't help but think there should be something on those terminals. Just glad it wasn't a PO changearoo that I wasn't aware of. Thanks! Link to comment Share on other sites More sharing options...
