tommcd Posted August 10, 2023 Share Posted August 10, 2023 Just purchased this unit. Has 4 slides and can't get them to work. Unit level, park brake set, seats forward, switch on not running, gen running , house batteries check good. What am I missing? The leveling system had to be reset before I got them to work but that was simply holding all 4 buttons for a couple seconds. I have checked all fuses and they seem to be good. The 20 amp breaker in the board with the relays isnt any good so I replaced it with a 20 amp fuse and still nothing. Any help ? Link to comment Share on other sites More sharing options...
Walker Posted August 10, 2023 Share Posted August 10, 2023 I don't believe my slides work with the ignition switch on. Link to comment Share on other sites More sharing options...
BradHend Posted August 10, 2023 Share Posted August 10, 2023 (edited) Ignition interlock as @walker mentioned, however nothing happens, or is there at least a click or a hum of some sort? Lights dim at all when you attempt to extend them? Salesman switch? Edited August 10, 2023 by BradHend Link to comment Share on other sites More sharing options...
Garry Donohue Posted August 11, 2023 Share Posted August 11, 2023 My ignition switch must be off for slides to work. Are all the cargo doors closed? And are all the cargo door switches working so the the system will know the doors are in fact closed? Link to comment Share on other sites More sharing options...
tommcd Posted August 11, 2023 Author Share Posted August 11, 2023 Best I can tell, mine doesn't have cargo door switches, but will try it with switch off tomorrow. I didnt get an owners manual with it but have found one online and it says ign switck off. Thanks for the info. Will get back to you tomorrow. Link to comment Share on other sites More sharing options...
Chargerman Posted August 11, 2023 Share Posted August 11, 2023 My 06 doesn’t have cargo door switches since none of the doors open upwards therefore they cannot be hit by a slide. Link to comment Share on other sites More sharing options...
tommcd Posted August 11, 2023 Author Share Posted August 11, 2023 Same here..Thanks Link to comment Share on other sites More sharing options...
Cubflyer Posted August 11, 2023 Share Posted August 11, 2023 (edited) I just discovered that my slides work even with house and chassis batteries ’off’. Not sure how or why, but they do! 2003 HR Endeavor…. all electric motor driven, no hydraulics.... Edited August 11, 2023 by Cubflyer added info Link to comment Share on other sites More sharing options...
Tom Cherry Posted August 11, 2023 Share Posted August 11, 2023 OK….read this topic. I posted an older drawing….it is for “hydraulic”, but the power for the slide switches follow the same logic. The parking brake must be set and you must have a light on the dash (ignition on) verifying that. That sends a Ground signal to the “control circuit”. Next…doesn’t matter if you have cargo door switches or not….there is a main feed to the switches center pins. Gotta have that. If you have cargo door switches they are in the circuit. The slide control relay has to work. It is NORMAL closed…or powered…but when the ignition switch is ON…it opens. SO…start with the center pins on the switches…if you have power (ignition off), then has to be the ground. If NO power to the switches center pins….then eigher the relay is bad (Bosch 5 pin) or there is fuse or mini (can be self resetting) or a “lever to reset” style… Link to comment Share on other sites More sharing options...
