planodp Posted August 22, 2023 Share Posted August 22, 2023 Good evening all, I have have been chasing a leak for a while now and I could never find it. Finally decided to replace the AC compressor. I have read on this forums that the front seal is hard to detach for leak. Well I ran into a bit of a issue. The low side extension adapter screw in just fine but it would not tighten. Now come to find out that the thread is mess up. The good thing is the compressor fitting is still good. I took the High side adapter and it screw right in and tighten up find. So now I'm looking to find the adapter. Anyone know where I might be able to find one. Please see the attach picture. Thanks for the help in advance. Duey Link to comment Share on other sites More sharing options...
Ivan K Posted August 22, 2023 Share Posted August 22, 2023 I have not seen one exactly like that but if you can use extra ports, there are options. I bet they have what you need in their catalog. Napa would probably find you some too. Link to comment Share on other sites More sharing options...
planodp Posted August 22, 2023 Author Share Posted August 22, 2023 Great I'll check Napa out thanks Ivan Link to comment Share on other sites More sharing options...
planodp Posted August 25, 2023 Author Share Posted August 25, 2023 @Ivan K I found a old school machine shop in Sherman that custom build just about anything kind of hose and fitting you want. Plus they also do engine work, engine block, crankshaft and head. They build my fitting for $55 buck. Thanks Ivan for the help!!!! 1 Link to comment Share on other sites More sharing options...
BigNick Posted August 27, 2023 Share Posted August 27, 2023 On 8/25/2023 at 3:26 PM, planodp said: @Ivan K I found a old school machine shop in Sherman that custom build just about anything kind of hose and fitting you want. Plus they also do engine work, engine block, crankshaft and head. They build my fitting for $55 buck. Thanks Ivan for the help!!!! Hey there Plano, I'm in the Dallas area too. I just found my dash ac isn't blowing cold , I totally clueless as to how the system functions and pointers would be appreciated. Link to comment Share on other sites More sharing options...
planodp Posted September 2, 2023 Author Share Posted September 2, 2023 On 8/26/2023 at 8:37 PM, BigNick said: Hey there Plano, I'm in the Dallas area too. I just found my dash ac isn't blowing cold , I totally clueless as to how the system functions and pointers would be appreciated. @BigNick Sorry, just now see this. Good thing for you I was just about to post the full replacement (parts list). If you have any question feel free to PM me. Coach is a 2004 Executive with ISM 500. This is not a how to but rather more of what part you will need to get this done. Sorry for the grammar! Not much of a writer. LOL The compressor is Sanden model U4756 ESSENTIAL SPECIFICATIONS Replaced by Aftermarket Version 4475 Click Here for Information Compressor Family: SD7H15 Style: HD Mount Type: SD7 Direct Long Ear ID: T92 B87 Refrigerant: R134A Displacement: 155.00 Rotation Direction: CW Oil Qty (cc): 300 Cylinder Head: CBA Port Angle: V Port Clocking: 12:00 Head Port Style: 1X14 Rotor Size: 125 Rotor Groove: PV6 Gauge Line to First Groove: 36.70 Gauge Line to Middle Groove: 45.60 Gauge Line to End Groove: 54.50 Coil Voltage: 12 Connector: 2 Wire Female Packard #15300002 Schematic: CLICK HERE Service Manual: CLICK HERE You can purchase it from http://acmeairparts.com/rvacheaterparts.html#!/New-Compressor-Direct-mount-Replaces-U4475-4756/p/391978071/category=16022426 $185.50 8/2023. I put PAG 46 oil into the reservoir and rotate the compress until oil come out of the either port. USE CAUTION YOU WILL NEED TO SAVE THE DIODE The new compressor had the wrong end. You'll need to cut off the old compressor end off as close to the hole down screw for the cable. Do the same but closer to the connector of the new compressor. The color code will not match. Black with with white tracer is hot. Side not, If you damage the low side extension you'll need: male O ring to female O ring #10 straight A/C compressor fitting W/134 port 6303 $17 on ebay. I had my custom made for $56 eBay seller From Mr.Fomoco Motorcraft (eBay) John Kulak 1220 Circle Ln, Bedford TX, 76022-6784 Receiver Drier 054-00001 for SCS/VCS. Diameter: 3” – Height: 8” – Inlet: #6 Male Insert O-Ring – Outlet: #6 Male Insert O-Ring. Includes moisture sensor. I use Murray 80-8032 / 33321 from ORilley under $30.00 Evacuate the system when done, then close all service ports. I have a 8 CFM pump and I let it run for 45 minutes +. Make a note of what the gauge is reading. Check the gauge it should be the same reading as before if there is NO LEAK. Break vacuum with Freon. I put as much in as I can before starting the engine. Finish up charging the system until it cold, don't over charge. Watch the low side and the high side gauge. My was at 25 PSI on the low side and around 200-225 on the high side. OH, make make sure you hear the condenser fan running. I said this cause my wasn't running. It make a big different. I hope this help! Link to comment Share on other sites More sharing options...
RWHenhouse Posted September 3, 2023 Share Posted September 3, 2023 On 8/26/2023 at 6:37 PM, BigNick said: Hey there Plano, I'm in the Dallas area too. I just found my dash ac isn't blowing cold , I totally clueless as to how the system functions and pointers would be appreciated. When my dash AC suddenly quit blowing cold, I found that the 20A fuse (rear run bay) for the condenser fan had blown. Replaced it, blew again immediately. Found that the fan motor (in the front, passenger side) had seized up. Replaced fan motor and all is good. Link to comment Share on other sites More sharing options...
BigNick Posted September 6, 2023 Share Posted September 6, 2023 Thankyou so much thats fantastic, I will check that fuse, Im guessing by run bay you mean the area inside where the AC breakers are? Link to comment Share on other sites More sharing options...
Ivan K Posted September 6, 2023 Share Posted September 6, 2023 30 minutes ago, BigNick said: Thankyou so much thats fantastic, I will check that fuse, Im guessing by run bay you mean the area inside where the AC breakers are? Rusty is referring to a 12V fan so the fuse should be where ever your 12V automotive fuses are, if you in fact have that fan. Mine is hydraulic so it depends on your setup. Link to comment Share on other sites More sharing options...
RWHenhouse Posted September 7, 2023 Share Posted September 7, 2023 3 hours ago, Ivan K said: Rusty is referring to a 12V fan so the fuse should be where ever your 12V automotive fuses are, if you in fact have that fan. Mine is hydraulic so it depends on your setup. Mine was in the engine compartment, up on the right (passenger side) in the electric panel covered by a plexiglass cover. It's a 20 AMP automotive fuse. Link to comment Share on other sites More sharing options...
