bmulvenna@hotmail.com Posted August 22, 2023 Share Posted August 22, 2023 2004 Dynasty. Fitting on the rear air tank leaks. Has only one 1/2 in line attached. Searched the parts list but can't find. Looks like it is Meritor but can't read all the numbers/letters. Link to pictures attached. Thanks in advance to anyone that can't help identify the part. https://photos.app.goo.gl/bqoD9WKkahk8gC2P9 Link to comment Share on other sites More sharing options...
Solution jacwjames Posted August 22, 2023 Solution Share Posted August 22, 2023 This might be it, I replaced mine when I went through my system, had to replace all PPV's but decided to replace any type of fitting that could fail so I replaced this check valve https://www.ebay.com/itm/152778312368?hash=item23924c0ab0:g:dQMAAOSw1QpaAhYU&amdata=enc%3AAQAIAAAA4NKxpC2VyFTLK2q%2FAPryUhFKAV8C6xgWtlTubhmM3yi9eVCzKyxx6d23mydCDQS2pw3F6D2lk%2F82j%2FA8jJ0VU8DmAogq7FdVZMSd7rYXhHeTky8Sd00X%2BQ438TcKgMukPm3DA64azawHWBCOp4Kfy0bQ3t8UpNxNnNsHmaZwlZQBzHgiIgI0unpnPMK2pvwPVTfJ3wRuU8jqgnQ1tHzXyeqfLPf9JBGptafN%2BxhXk6St9Vtofff3ccXPC0h5NstZif%2ByI8tzeGi%2BmX3gSMxJTTiJCr2xuyAEjYO2UrXRDd%2B5|tkp%3ABk9SR5i2nevDYg Link to comment Share on other sites More sharing options...
Bill R Posted August 22, 2023 Share Posted August 22, 2023 @bmulvenna@hotmail.com, I used the same part number as well that @jacwjames gives. That should be the one in your pics. Link to comment Share on other sites More sharing options...
bmulvenna@hotmail.com Posted August 23, 2023 Author Share Posted August 23, 2023 Thanks guys, that's it. Purchased one yesterday. Link to comment Share on other sites More sharing options...
jacwjames Posted August 23, 2023 Share Posted August 23, 2023 FWIW I believe in the downloads section there is a pretty good file showing the air system on the Monaco coaches. It does show the separate tanks with fittings on each. I used this to help me identify parts. I had the luxury of having my rig parked in my garage on ramps and had the time to remove a part, clean, and get numbers off it to confirm the part. I'd then shop for the part and get some pretty good prices. Since I had to replace all my PPV, which all started leaking within a month of each other), I also changed most of the Push To Connect fittings but found I could get decent prices at a local supplier of those. I also put together an emergency kit consisting of the different size tubing, union PTC fittings. I also kept the old PTC fittings just in case. After working on the system I now have a better understanding of how it works but also realize how vulnerable most of the line/fittings are. Any type of debris in the road could get thrown up under and take out a line. Link to comment Share on other sites More sharing options...
