63Hotrod Posted September 5 Share Posted September 5 There are 4 grommets one on each corner which pegs on the grill push into Anyone know where to get these Link to comment Share on other sites More sharing options...
Walker Posted September 5 Share Posted September 5 I ordered mine from rev group. Link to comment Share on other sites More sharing options...
klcdenver Posted September 5 Share Posted September 5 Walker could you please post a part number. Link to comment Share on other sites More sharing options...
Solution Walker Posted September 6 Solution Share Posted September 6 10112483 / coupling 15mm snaplock blk 73shore. This is what was on the invoice. I have a diplomat, but I would expect them to be the same. Link to comment Share on other sites More sharing options...
klcdenver Posted September 6 Share Posted September 6 Thanks. I have a diplomat and will be changing the radiator, cac and transmission cooler out this winter. Along with water pump, fan belt, idler arm and fan bearing. I have been looking for the radiator supports. Link to comment Share on other sites More sharing options...
Walker Posted September 6 Share Posted September 6 Glad to help. What coolant are you planning on using? I need to change mine soon and haven't decided what I want to use. Link to comment Share on other sites More sharing options...
klcdenver Posted September 6 Share Posted September 6 This is about as cheap as it gets also if you buy direct from Cummins 1 Link to comment Share on other sites More sharing options...
Gweedo Posted September 6 Share Posted September 6 Good stuff, put that in mine!! runs cooler Link to comment Share on other sites More sharing options...
