deputylynch Posted September 22 Share Posted September 22 I have a ScanGauge that works perfectly fine when plugged into my j1708 under the dash. When I try to use the j-1708 in the outside compartment underneath the driver seat all I receive is the battery voltage and no other information. Is this normal or do I have a back connection outside? This is on a 2005 Monaco Diplomat. Link to comment Share on other sites More sharing options...
Dr4Film Posted September 22 Share Posted September 22 Are you sure it is the same data bus? My guess is that it is not and that's why you don't see the data you are expecting. Link to comment Share on other sites More sharing options...
deputylynch Posted September 22 Author Share Posted September 22 They're both J1708 connectors with 4 wires into them but the one outside is only sending voltage information. Link to comment Share on other sites More sharing options...
Scotty Hutto Posted September 22 Share Posted September 22 On my 2006 Dip, the connector in the FRB only provides connection to the Bendix brake system and (I believe) the Allison ECM. I think it’s a J1587 (?) interface, but the same connector as a J1708. Those connections are only available with the Bendix and Allison software and proper connectors to a PC. I don’t believe a scangauge will connect to them. Link to comment Share on other sites More sharing options...
deputylynch Posted September 22 Author Share Posted September 22 (edited) Yes, after getting my camera and scanning the top of it that I couldn't see, It is for the brake system. I feel anybody else reading this will have an answer without finding out the hard way like I did. Again a great forum! Thank you!! Edited September 22 by deputylynch Punctuation Link to comment Share on other sites More sharing options...
