Tail Lights for 05 Monaco Exec
MJ.STIGER
Hey team who has replaced your 05 tail lights? I have tried the PDF and i get mixed results for what the replacement tail light is. Navigator or Explorer. Before i go buying something i would like to know if any one has updated their tail lights.
I now have a crack in my Passenger rear lamp. Yes i am at fault now comes the part of finding a replacement or replacing both rears to match.
Any help or models that have been used would be appreciated.
3 hours ago, David Pratt said:
The tail lights are from an 03 thru 06 Lincoln Navigator.
They are easy to find, just Google them.
Dave, I know you had an 05 Exec, but the 03 -06 Lincoln Navigator don't look like what I as shown below.  These are the same as 3 other 05 Exec's I've seen so fluff thought they were OEM. Are these 3rd party aftermarket?
There are a lot of aftermarket replacements out there and Monaco may have used them. The ones that Monaco used on the Exec were an aftermarket variant .that replaced the OEM taillights. If all else fails you might try a salvage yard.
On 9/23/2023 at 1:17 PM, MJ.STIGER said:
I find this image but it looks a bit a skew so its throwing me off.
I have the same stay as posted above.
The tail lights on the 05 executive looks like it is from a 1998-2002 lincoln navigator and monaco did use aftermarket ones at the time.... I don't think the original ones are sold anywhere but other either factory or other 3rd party aftermarket assemblies should work just fine different design but should have the same plugs/lightbulbs etc . Such as LincolnNavigatorAnzo Taillights - Chromehttps://www.tunersdepot.com/1999-lincoln-navigator-tail-lights-altezza-style/ks-altezza-tail-lights-9916.html
or
https://www.andysautosport.com/products/anzo__211109.html
Thanks all. I ended pulling the trigger on a set of these.
Then right after i saw a match set like the ones that came on the coach. I ended up picking those up and canceling the order above.
Funny after all my searching at length. The matching set shows up in the page after my purchase. I was looking High and Low for them. After figuring the  1st set will work on the 05 Monaco Sig.
Trying to keep things close to original as possible.
Found them on Ebay.  And i had searched high and low for them. They are the original style. Here is what the description said on Ebay.
"Aftermarket TYC Left Right 4 Tail Lamp Assemblies Fits 1998 Lincoln Navigator"
They where a Used set but in great condition. Better than mine. for about 90 dollars for the pair. Hope this helps.
