2006 Executive. No power to fresh water pump.
Duanebalogh
That's like asking to find a needle in a haystack!
It is located wherever Monaco decided to put it the day they were building your coach.
I would turn on a faucet with the water pump running then track down where the noise of the pump is coming from and you have located your pump.
It won't turn on so we can't listen to where it's coming from. We checked fuses and their all good.  Turn the facet on no water and no noise
Won't turn on so we can't hear it
Well that is a BIG bummer and a pickle of a position to be in.
Your next best solution would be to open up all compartments, sliding doors or whatever will open up easily and look around for your pump.
It will look something like this photo.
Don was right found it in the bay next to the wet Bay. Slid the carpet door and there it was. Thank you for all your help. So much appreciated
The water pump looks good but no power so no in search if why no power.  We have 3 water pump switches. 1 in the kitchen, 1 in the toilet room and one in our other sink so hopefully an easy fix. Thank you again for all tge great suggestions
  • Like 2
Time to pull your Prints.  Best Guess….since this is a 2006, you have the Intellitec Multiplex system.  Look in the rear closet.  If you have 5 large modules with a single stud and a red power cable, you have thr Intellitec MPX.  There is a legend or chart beside it.  Find the Module (they are ALPHA marked….like D, E, F, G or such.  Each one has a 10 Amp fuse on each of the 10 Circuits.  Use the legend and then home in on the individual fuse.  ODD ARE….thr Intellitec Module with the name “Output Module Relay.  There are maybe two of them.  The other 3 are for the incandescent lights that can be dimmed.  Your fluorescent fixtures and Fantastic vent fans as well as the pumps.  If you have a LIGHT on on the various switch panels.  Probably 5 switches.  Kitchen, Hall Vanity, Private Bath, Bedroom toilet and Utility panel in the Wet Bay.
Find the Module, Circuit and then the fuse…The Intellitec MPX replaced the original Intellitec Pump Controller.  But. Look at your prints.  There are all the circuits on the Modules….
  • Tom Cherry changed the title to 2006 Executive. No power to fresh water pump.
