Dave Shackelford Posted December 3, 2023 Share Posted December 3, 2023 Hi Guys, I have a 2005 Monaco Camelot 40 PDQ and the bedroom (Passenger Side) slide plastic motor gear is worn out. Missing teeth. Where can I find a new one ? (Plactic Gear) See Pics Thanks, Dave Link to comment Share on other sites More sharing options...
Bill R Posted December 3, 2023 Share Posted December 3, 2023 On 12/3/2023 at 3:02 PM, Dave Shackelford said: Hi Guys, I have a 2005 Monaco Camelot 40 PDQ and the bedroom (Passenger Side) slide plastic motor gear is worn out. Missing teeth. Where can I find a new one ? (Plactic Gear) See Pics Dave - I had the exact same problem. I replaced it with this metal gear and has been working flawlessly for the past year. Put some lube back in the case when your replace it. https://amzn.to/3UwBc5O Link to comment Share on other sites More sharing options...
Ron Shantos Posted December 3, 2023 Share Posted December 3, 2023 JUST ADDITIONAL INFO: Just today also replaced the 18:1 gear in a 2008 Beaver Contessa. The new ALL METAL GEAR was also purchased from Amazon. Lippert P/N 117292 bedroom ABOVE FLOOR SLIDE. NOTE: If the slide is "IN" it is necessary to cut a access hole in the bottom of the slide floor! ALSO NOTE that if the motor should fail there is NO Way to get a drill with 5/8" socket on the gear box to move the slide IN or OUT without a 36" long extension. Poor design to say the least! Just information that might be helpful. Ron 1 Link to comment Share on other sites More sharing options...
Bob Danny Posted December 4, 2023 Share Posted December 4, 2023 Hope this could help 1 Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted December 4, 2023 Share Posted December 4, 2023 This has been discussed at length on IRV2. You may find additional info there. https://www.irv2.com/forums/f115/need-help-finding-a-21-tooth-gear-for-my-bedroom-slide-out-544769.html Link to comment Share on other sites More sharing options...
Dave Shackelford Posted December 4, 2023 Author Share Posted December 4, 2023 Thanks, Baught 2 metal gears on ebay. many thanks, dave Link to comment Share on other sites More sharing options...
Paul J A Posted December 4, 2023 Share Posted December 4, 2023 "Sometimes" the design incorporates a reason for a plastic gear. I would not change from plastic to metal. Other components may be affected. Link to comment Share on other sites More sharing options...
Ken Smith Posted December 5, 2023 Share Posted December 5, 2023 Here is the company that originally sold units to Lipert. Link to comment Share on other sites More sharing options...
Donald Posted December 5, 2023 Share Posted December 5, 2023 The plastic gears are still available, metal gears are also. I have replace the gear .Back to a plastic gear .But carry a metal replacement also Link to comment Share on other sites More sharing options...
Dave Shackelford Posted December 5, 2023 Author Share Posted December 5, 2023 Hi Donald, Do you have a p/n for the plastic gear & where can I buy one ? thanks, Dave Link to comment Share on other sites More sharing options...
Scotty Hutto Posted February 12 Share Posted February 12 There are a couple of different manufacturers of these slideout motors that Monaco used (and these three were all used during different production runs of a 2006 Diplomat!): Venture (M8910-1.2 or M9600) Klauber (K01285L150) While the metal gear on Amazon will fit many, the other failure point is the metal clutch gear. If your failure point is the clutch gear, the metal gear will only make it worse. I suspect that the nylon gear was a “sacrificial” part designed to fail to save other parts, as Paul mentions above. Mine lasted 18 years, so I’m thinking if I can get another 18 years out of another nylon one, I’m good If you want to replace the nylon gear AND the clutch gear for the Venture M8910-1.2 version, you can find them as a set here for about $108. https://amzn.to/3SBG8DQ The other point of failure for the above floor (bedroom) slideout is the “gear pack” (aka the 20 or 21 tooth gear that drives the rack in/out). Fortunately I haven’t had to do that. Yet. Maybe Chris @throgmartin Can shed some light, but again, it appears Monaco used multiple variations - even on the same year/model Coach. Link to comment Share on other sites More sharing options...
