michaelivan Posted July 8, 2020 Share Posted July 8, 2020 The water line feeding the ice maker sprung a leak yesterday. It is the upper line that runs from the valve to the ice maker. We have an '03 Windsor 40PST. It appears that the only way to access the top connection is to pull the unit out of the cabinet. Just wondering if there is an easier way or do I just bite the bullet and pull the unit. Can it be accessed through the over toilet cabinet? How about through the roof vent? Link to comment Share on other sites More sharing options...
Steven P Posted July 9, 2020 Share Posted July 9, 2020 When mine leaked, it was at the hookup behind the fridge and was accessible through the rear panel. But mine leaked at the screw on connector. Link to comment Share on other sites More sharing options...
michaelivan Posted July 9, 2020 Author Share Posted July 9, 2020 Mine is leaking at the top where the water line connects to the ice maker inlet. Link to comment Share on other sites More sharing options...
DavidL Posted July 9, 2020 Share Posted July 9, 2020 Not sure how yours is fit, but in the time it took to type the question I could have mine out. Like four screws from the front (impact screw gun makes that fast) and pull the unit out. Once out the line is easily accessible. Good time to clean the unit inside and out and the cabinet. Link to comment Share on other sites More sharing options...
michaelivan Posted July 9, 2020 Author Share Posted July 9, 2020 I've had it out. New cooling unit 2 years ago and didn't think about the age of the line. Tight fit and the weight makes it awkward to move, even with the doors off. Just looking for any other suggestions. Link to comment Share on other sites More sharing options...
Guest Tim503 Posted July 9, 2020 Share Posted July 9, 2020 It is a pain and look for electric wires running from roof to floor along the sides. Put a box in front to slide it onto and use the flue cleaner rod before pushing it back in. The instructions say to clean the flue yearly, ridiculous. Look up for any nesting like wasps etc.. Link to comment Share on other sites More sharing options...
Dennis H Posted July 10, 2020 Share Posted July 10, 2020 Only way to access it is to pull the fridge. That said, it only has to be moved about a foot or so and if you're a contortionist you'll be able to get up there and remove it. IIRC it's a push in and seal it up kind of thing. Install is the reverse of removal....Dennis Link to comment Share on other sites More sharing options...
