Keith Russell Posted March 11 Share Posted March 11 You all are so helpful here so Im back for more guidance. I need a few minor parts for the coach - first is on the windshield wipers I need the lead cone inserts and the bolt on spray nozzle. Second is my hydraulic slide works when it wants to, sometimes the bottom works and other times it doesn't. It is a 6 post switch roughly 1'x1' looking to replace the switch first. Third thing is I have the 38 series kwikee step and needing the part number for the motor only and cheapest place to purchase it. Thanks once again to you all in advance Keith Link to comment Share on other sites More sharing options...
Ivan K Posted March 11 Share Posted March 11 Does you step motor and arm look like this? If so, there's your part number. I saved it from the old step when replacing the whole thing on our 2000 model. Link to comment Share on other sites More sharing options...
Bill C Posted March 11 Share Posted March 11 I think my step motor looks like that too. What’s the part number please Link to comment Share on other sites More sharing options...
Ivan K Posted March 11 Share Posted March 11 The motor number is in the picture. The mechanism would have to be reused or ordered from Lipert if broken but if you just need the motor, this is it. Link to comment Share on other sites More sharing options...
Ivan K Posted March 11 Share Posted March 11 Couple more wiper parts that should (?) be a match for 2002 Sig. Link to comment Share on other sites More sharing options...
Keith Russell Posted March 12 Author Share Posted March 12 Ivan that Anco 47-16 looks exactly right but is the center open? it needs to be open? The Anco 48-03 is right as well, just need to google search were to buy it. As far as the step, photo below, it works perfect, it's just when you close the door and the step retracts all the way in, after its in it makes a really loud knocking noise for about 4 seconds. sounds like a machine gun, people around start ducking like we are in the hood, lol. local RV guy says I need a motor bc it has worm gears in it, but wanted to check with you all. Thought it might be the other part the motor bolts too. Lastly the other photo is the switch for hydraulic slide 6 piston the back. Any part numbers or advice? Link to comment Share on other sites More sharing options...
jacwjames Posted March 12 Share Posted March 12 My steps started doing the same thing and I replaced the motor and lever arm assembly. Found it on Ebay back ~12 years ago. It may be the plastic gear that the motor mates to, only way to tell is pull it apart and take a look. 1 Link to comment Share on other sites More sharing options...
Ivan K Posted March 12 Share Posted March 12 Keith, yes the center on that splined cone is open to slide on the shaft. What Jim said above is what I would do with the step assembly. Sometimes, probably most of times, the whole circumference of the big gear is not actually used and can be repositioned to use the good section. Until next time.. I don't know if the one I have is any good since the step got crushed by a truck. I don't know part number for the switch because I just took mine apart, cleaned and slightly bent the contacts inside. Works for years, like new. It is a two circuit momentary on-off-momentary on, might have a number on it? I never had to replaced my switches, unless they melted it can be fixed. That way I don't have to wait and guess the size fitment. 1 Link to comment Share on other sites More sharing options...
Keith Russell Posted March 12 Author Share Posted March 12 That is a great idea, I will pull apart the switch and try that myself. Thank you! Link to comment Share on other sites More sharing options...
jacwjames Posted March 12 Share Posted March 12 So I tried to find the PN for the step motor/gear box that I replaced but couldn't find it. But I think this is what I bought https://www.ebay.com/itm/156031447198?itmmeta=01HRSH5P1A9YZQRSBFTDKEGMS8&hash=item245432f09e:g:bawAAOSwg2VkWT~1&itmprp=enc%3AAQAJAAAA8PqqxrvNSi9vmeOIQy4r%2BkXl54MlSiuDDh7pQ1uF9YVCd62qru1N7U%2FbZCoYNgID6L%2FgA2HJUXMNbxLN7C%2ByOxCAjHzxwcJGxIZoJS4lh1%2F5xym33gKsLhrK1KBKkf8rKXWP0YWTPedmGSHsFt8cByjDmA6BxBz%2BsRWhfRj3CqpSgY01xhJ2WA8UPoEi5OBYd8znELiswI%2BfinKsqQSbmDKG8W%2Fj9OPH%2F4msstTWUgAAysK6FctX%2BNJ%2B6MnQmKwlk%2FMmYa%2FuR0S0Bj4QeO%2BU1cg31lkHibwJmhlT2kdlcik7z9tpkjZdlmS1vi4hcKfvOw%3D%3D|tkp%3ABk9SR-zglrHGYw That was 2011, price was $195, it's double that now. There are aftermarkets availabe a lot cheaper. https://www.ebay.com/itm/145031860768?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D261916%26meid%3D351026e5cd4541838fdcde531ba56628%26pid%3D101875%26rk%3D2%26rkt%3D4%26sd%3D156031447198%26itm%3D145031860768%26pmt%3D1%26noa%3D0%26pg%3D4429486%26algv%3DSimplAMLv11WebTrimmedV3MskuWithLambda85KnnRecallV1V2V4ItemNrtInQueryAndCassiniVisualRankerAndBertRecallWithVMEV3CPCAutoWithCassiniEmbRecall&_trksid=p4429486.c101875.m1851&itmprp=cksum%3A145031860768351026e5cd4541838fdcde531ba56628|enc%3AAQAIAAABgHD%2FO%2BVoFoPPIoZ2g0kOZxWd85mWuIHekSp3qag7zFfwObZeQoitzE%2FDCfcejfO%2BzOLmzZmy11RrgWpA56KM9DpasK%2BGtGYwCFvgaK6ijP5AqShEUhT8f2oX6hvndJ3G0oWH8DD1DlBWseQltpxcSDW2Uu52NrseaxeINpsrDP6vx7ny%2BkPKauMa3yeSanWiinWBsVPZdc94c8XLZhP%2BsGTTshTDLKj28wBbXFG1X8DTVBQd9o2LV6LQk1JektlYgT4NmJBUtR5izvJ728t94v4%2FtFhEU7TB5AUc1BKI0Wpvd5NvQzMbBUBnIfvFQoJtFr1lbC2tH9ARFmQF9J2np%2B%2BACSiTeC3GX2nPkKw04fjWwvjVaIhzo2cWEQfFxPK4GtImd%2BYp%2ByLYOSMjjIAiEvZoVHPgW8tY%2Fzyt9ieUL%2BSYb0Lr%2B%2FDc8kbm82Gnfk4N6Ay1%2F1LtXM5vCcdvU37TC3I7gt4Aw57sGHntggGGbFoJquw50tPxuYXzhmchLD2gbg%3D%3D|ampid%3APL_CLK|clp%3A4429486&itmmeta=01HRSH6EKNGA1WXA4FV8JQD974 Link to comment Share on other sites More sharing options...
veraken Posted March 12 Share Posted March 12 I replaced mine with the following part from Autozone https://www.autozone.com/electrical-and-lighting/window-motor/p/dorman-oe-solutions-window-motor-742-277/54847_0_0 Check your motor orientation. Here is same motor with reversed orientation https://www.autozone.com/electrical-and-lighting/window-motor/p/dorman-oe-solutions-window-motor-742-276/54846_0_0 Here's a pdf that may help Kwikee Step Troubleshooting Guide.pdf Link to comment Share on other sites More sharing options...
