rpasetto Posted March 17 Share Posted March 17 (edited) Hunting in the bedroom for the switch which controls the fan and the Aladdin "joystick" we found this array of controls below. Thinking of relocating the switches since they're basically inaccessible without moving the mattress. Also wondering if this was the 'standard' Monaco placement on models with windows at the side of the bed. My tentative plan is to build a shallow box to match and mount alongside the window valence. I may have to rotate the Intellitec switches 90 degrees to fit. If anyone has run into this switch placement, how did you deal with it? Edited March 17 by rpasetto fix typos Link to comment Share on other sites More sharing options...
redstickbill Posted March 17 Share Posted March 17 Rick, In my 07 coach the bedroom has closets alongside of the bed, the switches you show are mounted in the side of the cabinet, the Aladdin "joystick" is mounted next the monitor with the fan switch below it, the multiplex switches are mounted below the Aladdin monitor. Bill B 07 Dynasty Squire VI Link to comment Share on other sites More sharing options...
Florida Hog Man Posted March 18 Share Posted March 18 Agree with poor placement and I’d like to relocate mine also. Hope it can be done. I’m doubtful there is enough cable - did you check? Link to comment Share on other sites More sharing options...
Tom Cherry Posted March 18 Share Posted March 18 GENERIC COMMENT. The lighted switches on the two keypads are part of the Intellitec MPX system. There is usually a 3 wire (maybe #14) connector. Splicing in 3 wires to lengthen would not be an issue….just use a ratcheting crimper and high quality butt splices. SOME of the MPX switches may, doubt in this case, have an additional 2 wire pigtail. Same deal….splice as needed. The fan control switch should be the same. Probably or hopefully #12 stranded. Should NOT be an issue. Joy Stick….no idea….don’t know what the other switch on the left is. As long as no “proprietary” or special wiring cables..good to go….the Joy Stick may be a MPX with shield…..lots of options for finding similar. Link to comment Share on other sites More sharing options...
rpasetto Posted March 18 Author Share Posted March 18 16 minutes ago, Tom Cherry said: GENERIC COMMENT. The lighted switches on the two keypads are part of the Intellitec MPX system. There is usually a 3 wire (maybe #14) connector. Splicing in 3 wires to lengthen would not be an issue….just use a ratcheting crimper and high quality butt splices. SOME of the MPX switches may, doubt in this case, have an additional 2 wire pigtail. Same deal….splice as needed. The fan control switch should be the same. Probably or hopefully #12 stranded. Should NOT be an issue. Joy Stick….no idea….don’t know what the other switch on the left is. As long as no “proprietary” or special wiring cables..good to go….the Joy Stick may be a MPX with shield…..lots of options for finding similar. Thanks, Tom. If I need to extend the wires I'll also shut down power to the intellitec system... just in case. To the left of these are a 110V outlet and an "RJ" telephone connector which I will leave as-is. Link to comment Share on other sites More sharing options...
GMan81 Posted March 18 Share Posted March 18 on the Aladdin switch there are difference lengths. Don't know how far you need to move the switch. Northwest RV Supply has some of the cables 866-678-7467 Hope this helps. Marlon Link to comment Share on other sites More sharing options...
amphi_sc Posted March 19 Share Posted March 19 My Patriot Thunder has the almost same setup by the bed but the mattress doesn't cover them. My fan switch is overhead between the overhead reading spot lights easily reached by either occupant. Your mattress must be much thicker. The pillows do affect the unused phone and seldom used 120v socket. When you raise the bed up and unscrew the plywood frame to gain access to the wiring you might find enough slack there to accomplish relocation without splices. 2 Link to comment Share on other sites More sharing options...
DBRV.0 Posted March 19 Share Posted March 19 (edited) 3 hours ago, amphi_sc said: When you raise the bed up and unscrew the plywood frame to gain access to the wiring you might find enough slack there to accomplish relocation without splices. I discovered this wiring when I replaced my mattress for a queen size, which was narrower than OEM's RV King. With the mattress gone, I wanted to modify the plywood base, so I temporarily removed all of the wood. Took notes on the wiring underneath, and confirmed that my wiring comes up from below then splits to the left and right of the bed under where the pillows are. On the sides of the bed base (pillow area), my unit has a plywood-based covers between the wall and floor which are held in place with screws. There may be a couple to few inches of extra wire available, but probably not 6. Tip: it may not be necessary to fully remove the mattress. Just pull it away from the wall and unscrew the plywood piece that sits under your pillows. Wiring will be accessible. Edited March 19 by DBRV.0 1 Link to comment Share on other sites More sharing options...
rpasetto Posted June 25 Author Share Posted June 25 (edited) Update: Switches are now in a more accessible place. Not the way I would have designed it from scratch, but now easily accessible. Thanks to all for the advice. I extended wires from the under-bed area. Routing the three cables: Intellitec, Fan and Aladdin, around drawers was a bit tricky but protected with wireloom now. Scariest part was drilling a 1" hole thru the Corian top which then goes into the lower LH corner of switch box. Edited June 25 by rpasetto 3 1 Link to comment Share on other sites More sharing options...
Tom Cherry Posted June 25 Share Posted June 25 1 hour ago, rpasetto said: Update: Switches are now in a more accessible place. Not the way I would have designed it from scratch, but now easily accessible. Thanks to all for the advice. I extended wires from the under-bed area. Routing the three cables: Intellitec, Fan and Aladdin, around drawers was a bit tricky but protected with wireloom now. Scariest part was drilling a 1" hole thru the Corian top which then goes into the lower LH corner of switch box. GREAT JOB. Thanks for the pictures and follow up Link to comment Share on other sites More sharing options...
