VinceB Posted April 19 Share Posted April 19 What I have: Can it be replaced with this? Link to comment Share on other sites More sharing options...
Simplysmn Posted April 19 Share Posted April 19 We found a 4000 watt inverter/charger and installed it in the bay. Link to comment Share on other sites More sharing options...
jacwjames Posted April 19 Share Posted April 19 I think your current inverter has two outputs going to you main panels. The Freedom only has one output based on the spec sheet I looked at. Link to comment Share on other sites More sharing options...
VinceB Posted April 19 Author Share Posted April 19 21 minutes ago, jacwjames said: I think your current inverter has two outputs going to you main panels. The Freedom only has one output based on the spec sheet I looked at. What would be the harm in tying the 2 panels together? Mmmm... I'm a bit confused. Check out page 25 at https://xantrex.com/library/inverter-chargers/freedom-458-inverter-charger/owners-guide/ Link to comment Share on other sites More sharing options...
jacwjames Posted April 19 Share Posted April 19 I'll let smarter minds then mine answer that one. Not saying it can't be done but I'm not giving advise out of my wheel house. Link to comment Share on other sites More sharing options...
cbr046 Posted April 19 Share Posted April 19 We have a Xantrex 458 in our 2003 Endeavor. It should be directly compatible with your Legend as our coaches are sister ships. You may need to run different wires for the remote panel. My biggest gripe is every time I plug in to shore or generator it "pretends" the batteries are weak and force charges them for 30 - 60 minutes. Even if they're fully charged they get super-charged (no such thing). If you plug in for a week at a time or so that should be fine. - bob Link to comment Share on other sites More sharing options...
waterskier_1 Posted April 20 Share Posted April 20 If you need two AC outputs, then this will not work (without rewiring the coach). The model you needed is 81-2020-12. I can't determine that the remotes or wiring are interchangeable. - Rick N Link to comment Share on other sites More sharing options...
