richmelcole@sbcglobal.net Posted July 21, 2020 Share Posted July 21, 2020 Was thinking about replacing the propane gas cooktop with induction type. Has anyone done this upgrade? Rich Link to comment Share on other sites More sharing options...
sheena154 Posted July 21, 2020 Share Posted July 21, 2020 (edited) 24 minutes ago, richmelcole@sbcglobal.net said: Was thinking about replacing the propane gas cooktop with induction type. Has anyone done this upgrade? Rich We replaced ours with a double induction cooktop five years ago and it's worked great. He used an extension cord to plug into the washer/dryer outlet and we had a granite piece installed to cover the area now vacant so everything lays flat. One bonus is that we now have space underneath to hold the stove and sink covers. Tricia N. '06 Diplomat Edited July 21, 2020 by sheena154 Link to comment Share on other sites More sharing options...
Ron Jones Posted July 21, 2020 Share Posted July 21, 2020 I wrote an article on what we did. Send me your email and I will send it to you. It has pictures. R E J at G T E dot N E T Ron Jones Link to comment Share on other sites More sharing options...
Onthego Posted July 21, 2020 Share Posted July 21, 2020 Remember induction burner use about 1800 watts , when set on highest setting. There are some that are around 1500 watts. Just thinking about wiring size and fused If built in. Link to comment Share on other sites More sharing options...
6Wheels Posted July 21, 2020 Share Posted July 21, 2020 1800 watts is 15A @ 120VAC This is maxed out for 15A circuit, so when running the cooktop make sure it is the only thing running on that circuit. Link to comment Share on other sites More sharing options...
dlelsner Posted July 21, 2020 Share Posted July 21, 2020 (edited) I did this replacement about 2 years ago. Biggest problem I had was getting power to the area. What I did was to run a new cable behind the cabinets, under the shower and bath sink into the back bedroom under the cabinets there then into the cabinet where the washer/dryer would have been. I then plugged into the outlet prewired for the W/D. Was a lot of work but worth it! We love Induction. as we also have it in our home. The counter was fixed by adding new pieces of the same type material. then I had a cabinet shop glue it all together. 15 hours ago, richmelcole@sbcglobal.net said: Was thinking about replacing the propane gas cooktop with induction type. Has anyone done this upgrade? Rich Edited July 21, 2020 by dlelsner Link to comment Share on other sites More sharing options...
