4rickyg Posted May 30 Share Posted May 30 05 H R Navigator. The air operated step cover has been operating intermittently for a while. Finally decided not to open anymore. I removed the rocker switch in the passenger side armrest. There is 14 V to the red wire labeled step cover 1. I use the jump wire over to step Cover 2 nothing, and then step cover 3 and nothing happened. Started to look around under the second step where all the hydraulic valve for the slides are.Did not see anything for the step cover. Trying to figure out where to look from here? As always appreciate the help from this group.. Link to comment Share on other sites More sharing options...
Ivan K Posted May 30 Share Posted May 30 I would expect a two way Mac valve with flow adjustment screws. Ours is mounted in direct view left of the generator, will have 3 lines going to it. Link to comment Share on other sites More sharing options...
jacwjames Posted May 31 Share Posted May 31 Mine is also mounted on the firewall above the generator. Here's a picture of it 1 Step Cover Solenoid.pdf 1 Link to comment Share on other sites More sharing options...
4rickyg Posted May 31 Author Share Posted May 31 Thank you we'll check into that tomorrow. Link to comment Share on other sites More sharing options...
4rickyg Posted June 14 Author Share Posted June 14 I found the Air valve with three lines on the firewall. Unhooked everything and cleaned it up now it is working. Just your typical corrosion for a twenty year old rig. Thanks for the help Link to comment Share on other sites More sharing options...
