tommym Posted September 5, 2020 Share Posted September 5, 2020 I have a 2002 Monaco Executive with a Cummins ISM500 engine. I cannot start the engine with the dash mounted ignition switch. The engine will turn over but will not start. I can go the rear start box in the engine compartment and it will start just fine. Does anyone have any suggestions regarding how I might troubleshoot this issue? Link to comment Share on other sites More sharing options...
philcarrell Posted September 5, 2020 Share Posted September 5, 2020 There is a rocker switch in rear bay near the engine srart switch see if it is on rear start or front start Link to comment Share on other sites More sharing options...
tommym Posted September 5, 2020 Author Share Posted September 5, 2020 The engine starts just fine from the rear start box. Link to comment Share on other sites More sharing options...
merkur89xr4tiride Posted September 5, 2020 Share Posted September 5, 2020 That is a good problem to solve. Never experienced any problem like that. But sicne it will start from the rear switch and only turn over from the front switch, I would guess there is more than one function these switches do, i.e. at least engage the starter and the fuel pump. I would guess the front is not engaging the fuel pump and I would have someone at the reat of the coach while you turn the front switch to determine f they can hear the fuel pump. Other than that, I wouldn't have a clue where to begin. Murray Walker 01 HR IMperial that was sold last month. Link to comment Share on other sites More sharing options...
tommym Posted September 5, 2020 Author Share Posted September 5, 2020 I didn't know this engine had an electric fuel pump. Link to comment Share on other sites More sharing options...
Johnny Chambers Posted September 5, 2020 Share Posted September 5, 2020 (edited) Did you understand Phil's answer about that rocker switch . Also I had a ign. switch do the very same thing . Those ing. switches are CHEVY truck switches you can buy at any NAPA parts store . GOOD LUCK !!! Edited September 5, 2020 by Johnny Chambers Link to comment Share on other sites More sharing options...
Dennis H Posted September 5, 2020 Share Posted September 5, 2020 Well I'm confused, so please help me. Let's start with the rear run box. Is the switch on the rear or front? Make sure it's toggled to the FRONT. Then try to start with the key. If it doesn't work, then leave the key ON toggle the switch to rear and try to start it. If this is what you've done, please forgive me for not understanding. If this works, then you have a bad ignition switch. Check the connections on the back of the switch first. If they're ok then it's easiest to replace the switch rather than trying to take it apart and mess with it.....Dennis Link to comment Share on other sites More sharing options...
tommym Posted September 5, 2020 Author Share Posted September 5, 2020 If I put the rocker switch on "front" and try to start with the ignition switch, the engine will not start. If I leave the ignition switch in the "on" position and change the rocker switch to "rear" it will start just fine. I'm having a little problem with the culprit being the ignition switch, simply because the switch seems to be working properly when it has to be in the "on" position in order for the levelling system to work, the electric door step to work, and it also works as far as turning the engine over. Link to comment Share on other sites More sharing options...
Ivan K Posted September 5, 2020 Share Posted September 5, 2020 If you start it from the rear and then flip the switch to "front" position and it keeps running, your ignition switch does not work right or isn't wired correctly. It may be interrupting your ignition power while cranking, just like it does for accessories. 1 Link to comment Share on other sites More sharing options...
tommym Posted September 5, 2020 Author Share Posted September 5, 2020 I've never tried that, but I will tomorrow. Thanks. Link to comment Share on other sites More sharing options...
dl_racing427 Posted September 6, 2020 Share Posted September 6, 2020 In addition to triggering the starter motor, the ignition switch has to supply power to the shutdown solenoid on the injection pump. It's possible that when the rear panel is selected, this circuit is supplied via another path. It sounds like this part of your ignition switch is defective, or there is a broken wire somewhere. Link to comment Share on other sites More sharing options...
Paul A. Posted September 6, 2020 Share Posted September 6, 2020 I would replace the 18 year old ignition switch. May not be defective, but a good proactive P M step. Paul A Link to comment Share on other sites More sharing options...
granvillebarker Posted September 6, 2020 Share Posted September 6, 2020 (edited) Looking at my schematics, I’d suspect the front/rear switch may be failing. Check to see if the LEDs that are lit up to the right of the rear switches are the same one one with the switch on front and rear. Here are the LED’s active for me. This is with the engine off in the pic below. It looks like the yellow ign relay light would be off if that switch was failing when in the front position. Edited September 6, 2020 by granvillebarker Link to comment Share on other sites More sharing options...
