trstaska Posted November 28, 2020 Share Posted November 28, 2020 Ongoing problem with door sticking. How do I adjust?trstaska 06dip Link to comment Share on other sites More sharing options...
DavidL Posted November 28, 2020 Share Posted November 28, 2020 (edited) which door? And when you looked at it - Where is it sticking? The door to frame? The latch? Too little info. Edited November 28, 2020 by DavidL Link to comment Share on other sites More sharing options...
Blacknight Posted November 28, 2020 Share Posted November 28, 2020 I had a sticking entrance door on my coach because the swing arm assembly became too worn to function as designed. The arm has a rivet in the center that becomes loose over time, you can try and peen the rivet tight but it didn't last long for me so i replaced with new. Entry Door Hinge Swing Arm Assembly I 08408401.webarchive 1 Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted November 28, 2020 Share Posted November 28, 2020 Send me a PM to jbee99807 @ gmail dot com. I will send you the adjustment procedure. Chuck B Link to comment Share on other sites More sharing options...
veraken Posted November 29, 2020 Share Posted November 29, 2020 Here's a pdf that may help you. Door Bushing Replacement & Latch Adjustment.pdf Link to comment Share on other sites More sharing options...
KevinH Posted November 29, 2020 Share Posted November 29, 2020 I’ve had trouble with my door also this last summer we were locked in the coach ended up opening the window reaching out opening the door. After I took everything apart one of the door rod clips broke I was able to find something that worked at the hardware store but it wasn’t an exact fit. Does anybody know where to get parts for these latches? Link to comment Share on other sites More sharing options...
Grampy OG Posted November 29, 2020 Share Posted November 29, 2020 On 11/28/2020 at 10:57 AM, Blacknight said: I had a sticking entrance door on my coach because the swing arm assembly became too worn to function as designed. The arm has a rivet in the center that becomes loose over time, you can try and peen the rivet tight but it didn't last long for me so i replaced with new. Entry Door Hinge Swing Arm Assembly I 08408401.webarchive 7 MB · 27 downloads How does one open a file with a WEBARCHIVE extension? This looks like a document I could use. Link to comment Share on other sites More sharing options...
Blacknight Posted November 29, 2020 Share Posted November 29, 2020 Sorry about that, try this address: factoryparts@veurinksrv.com thanks Steve Link to comment Share on other sites More sharing options...
Steve_Knight_2001 Posted December 1, 2020 Share Posted December 1, 2020 I had same problem with door not opening. Btw.. this is separate from screen door swing arm rivet issue. I left coach to get a few groceries from local market. When I returned I was unable to open the main (only) door. My dog was laying comfortably inside all nice and cozy while I tried to no avail open the door. I called AAA and tech showed up, he ruined 4 of the 38 screw heads as removing door seemed last resort. One last attempt was to toggle door while pushing and it opened.. gave his huge dog 2 hotdogs. Lol Repair not easy because of all screws involved in process but will find and give link if needed. Basically taking inside door cover off and adjusting a few nuts. Link to comment Share on other sites More sharing options...
trstaska Posted December 1, 2020 Author Share Posted December 1, 2020 I took my door apart today and made the top and bottom linkage adjustments. Works great now!! Thanks to all. Tr Staska 06 Dip Link to comment Share on other sites More sharing options...
