StellaTariche Posted February 19, 2021 Share Posted February 19, 2021 Hi All, On my 2000 Diplomat firewall, I have a stencil that says "Battery Isolator Lock-Out", and a bunch of wires. Today I found a photo online of a Diplomat firewall WITH the relay connected! (photo below) So now I know which wire goes where. BUT, I don't actually know: what this particular relay does (functionally) the relay part number Anyone have any insight into either question? Thanks, - John John Taylor 2000 Diplomat Link to comment Share on other sites More sharing options...
Dr4Film Posted February 19, 2021 Share Posted February 19, 2021 I believe that relay may have something to do with the charging system specifically when the engine AND generator are both running at the same time. 2 Link to comment Share on other sites More sharing options...
StellaTariche Posted February 19, 2021 Author Share Posted February 19, 2021 Hi Richard, That is my guess too. I’m not sure who removed it or why... (I’m the 2nd owner, and the first owner “fixed” a lot of things by unplugging them) ...like “the jacks are down BONG” (in reality, low hydraulic fluid), “...so let’s disconnect the warning BONG...” kinda stuff. I’ll keep hunting, I think you are on the right scent... - John 1 Link to comment Share on other sites More sharing options...
PeterSchweizer Posted February 19, 2021 Share Posted February 19, 2021 John, that's always the issue with RVs n things. As you can see looking at any one post, there are lots of opinions, guesses, and way off the charts ways to repair somthing and many, many.. levels of workmanship by owners and even certified repair presons/shops. As with anything be educated in it: Buyer Beware ! 2 Link to comment Share on other sites More sharing options...
Windsornut Posted February 20, 2021 Share Posted February 20, 2021 The problem on the system can be over taxing the battery charging alternator on the engine while long distance driving. I my case, the Lithium battery bank for solar panels is so large, it can pull way more energy/amps than the alternator can supply on a single steady charge so, something has to be installed to keep from cooking the alternator and that is an isolator of some sort. I installed a Li-bim (Lithium battery isolator manager) in place of the old isolator system components. Basically what it does is allow charging of house Lithiums, chassis lead acid batteries and then gives the alternator a rest (Cooling) these generally operate on a timing system rotating among all 3 stages while you drive. To be clear, I removed 3 major original pieces, charging 3 wire brick (trickle charge chassis batt. maintainer). (Isolator delay relay delay Diesel) And battery isolator relay. LiBim replaced battery isolator relay. My point is: All of these orignal components work well for lead acid or agm batts. Also including shore power charging. (All components are needed obviously). One more thing, I have found that many of the small black relays on the coach system are the same and available at places like Amazon. You have to look for small print. I would be interested to see an expansion of my thoughts on this incase more detail is needed. Hope this helps Link to comment Share on other sites More sharing options...
StellaTariche Posted February 20, 2021 Author Share Posted February 20, 2021 (edited) Hi Greg, Many thanks for the explanation. It all makes sense. I too replaced those components for those same reasons (slightly different components, same idea ) so it makes sense why the missing relay seems to have no effect. Multiple charging sources into multiple battery banks with differing chemistries is challenging. The low internal resistance of lithium banks means monitoring the charging sources so they aren’t stressed and won’t melt. Greg, Question: do you still run a mix of lead acid/agm with your lithium banks? I’ve thought about eliminating the entire lead acid portion for a lot of reasons (huge weight reduction, much simpler system), but have held off for two reasons: (1) my current LFP chemistry does not like cold, and I live in Colorado Springs at 7200’ above sea level. I keep the house banks heated using battery heating pads. Effective, but a hack, and also subject to failure. (2) starting the main engine of of a LFP bank can be a problem, even at proper temperatures. Normal current discharge for even the most egregious loads (in my case, the A/C and microwave) is still fractional C (under 240A at 12V). Starting circuit would have to be much higher, if only for the cranking time (1000A at 12V for up to 15 seconds I’m guessing). That makes fusing the starting and house circuits into two paths, and complicates life. BUT, I could see adding an additional lithium bank (dual use - house and starting bank), but using is in stead of LiFePO4(LFP), adding a LiFeYPO4 (LFYP) bank. The yttrium allows lower temperature charging and discharging, exactly what I need. And, I could simplify my charging setup, as they have the same profiles. I would keep the existing LFP banks (sunk cost, work fine), but add another dual use bank of LYFP that could be fused for time limited high current discharge connected to the starter circuit (main engine and genset). The LYFP bank, on its own BMS, etc, would also be useful in extreme cold situations (albeit at a much reduced capacity) until the main LFP banks were within charging/use temperature range. Greg, (and others reading this) Does this make sense, or am I over thinking it, and there is a better way? Thanks again. - John Edited February 20, 2021 by StellaTariche Link to comment Share on other sites More sharing options...
Windsornut Posted March 18, 2021 Share Posted March 18, 2021 I am using LFP for the house and still have the huge lead acid batt. for the chassis. I know battleborn has recently introduced a heated version of Lithium batt. but, I haven't studied them or any results/opinions yet. Seems B-born just added a heater to each batt. I have no knowledge of the LFYP batts. as of yet. After about 5 years of trouble free use of LA chassis batt. I am very happy and it will be some time before I would consider making a change. (zero corrosion and tiny amount of maintenance & water). Greg Link to comment Share on other sites More sharing options...
StellaTariche Posted March 18, 2021 Author Share Posted March 18, 2021 ooohhh, I just started looking into replacing my two big starting batteries with a super capacitor. Very interesting. Many truckers are doing it. Maxwell makes a single super capacitor which will put out 1800 CCA for 10 seconds, with multiple repeats allowed before recharging the super capacitor is needed. And, it is in parallel with your main house bank. They claim that a house bank with 7v (really dead) is enough to charge the super capacitor in about 15 min. $800 form multiple sources. Link to comment Share on other sites More sharing options...
Frank T Posted February 5 Share Posted February 5 I accidentally disconnected this relay, it was cycling with the generator start. I have two blue wires on same plug, two yellow and a white. I cannot tell on this picture what goes where. Any help would be appreciated. Link to comment Share on other sites More sharing options...
StellaTariche Posted February 5 Author Share Posted February 5 I too have this issue. Still is disconnected, so I'm interested in what others say too. thanks, - John Link to comment Share on other sites More sharing options...
dl_racing427 Posted February 6 Share Posted February 6 On 3/18/2021 at 5:27 PM, StellaTariche said: ooohhh, I just started looking into replacing my two big starting batteries with a super capacitor. Very interesting. Many truckers are doing it. Maxwell makes a single super capacitor which will put out 1800 CCA for 10 seconds, with multiple repeats allowed before recharging the super capacitor is needed. And, it is in parallel with your main house bank. They claim that a house bank with 7v (really dead) is enough to charge the super capacitor in about 15 min. $800 form multiple sources. I would not parallel it with my house batteries. You run the risk of draining your batteries and being unable to start the engine. I'd keep an automotive sized AGM battery in parallel with the capacitor bank, keeping the house and chassis systems isolated. Also, beware of counterfeit Maxwell capacitors, especially on eBay, and to a lesser extent Amazon. Link to comment Share on other sites More sharing options...
Tom Cherry Posted February 6 Share Posted February 6 OK....here's MY TAKE ON IT. FIRST....let's TRY the Prints.... There is, a Battery Cutoff RELAY in one of the later prints. The LARGER drawings were divided into FOUR pages. You have to open up the files...blow them up and then rotate to get a clear view.... BUT.....IF, you go back to the PICTURE in the very first (old one) post or stated the topic, that is a STANDARD BOSCH relay. SO, there are 4 wires in the picture. TWO are "LOOSE". They are on each side. THOSE go to the RELAY COIL. They do NOT have any polarity so either will work on terminals 85 and 86. NO BIG DEAL. NOW, FIRST....let's do a little "Relay 101". On the BOSCH relays (called 87 or 87A) that are used in our MH....here is the contact configuration. These Relays are designed, typically, so that "SOMETHING" happens when you energize the coil. This is called a DPST switch or Relay. Terminal 30 is the INPUT and if the Relay is ON....then there is a circuit to Terminal 87. Kill the power to the coil or deenergize it...then there is a circuit between Terminal 30 and Terminal 87A Look at the Diagram Terminals 85 and 86 are the COIL connections. Polarity does NOT matter....except when Monaco decides to do NEGATIVE switching and there is a GROUND signal. But in MOST cases, there will be 12 VDC on one of the wires and the other will be GROUNDED. So, the two outer or loose wires go to the COIL. If you turn ON the ignition, odds are....ONE of these wires will have power. NOW...in the picture, there is a "plug" below. Look at the Diagram. That plug is connected to Terminals 30 and 87A. THAT means that when the RELAY is NOT energized....there is a CIRCUIT between Terminal 30 and Terminal 87A. BUT, when you apply power to the coil....then whatever is on Terminal 30 is "Switched" or connected to Terminal 87. First find the HOT or the "power on when engine is turned on". That will go to 85 or 86. Now...with NO ENGINE Running....ONE should be a GROUND. That is to energize the coil. It goes to Terminal 85 or 86. Once you have these two wires identified....the OTHER two are NOT "Polarity Sensitive: Attach either one to Terminal 30 and the OTHER to Terminal 87....BINGO...it should work... BUT....again....look at your prints... Link to comment Share on other sites More sharing options...
