powersltc Posted March 2, 2021 Share Posted March 2, 2021 Any help would be Appreciated. I have a 2004 Monaco Executive. Air leveling was working. Then I attempted to level but couldn't level. I canceled the process. The next morning the reset button light was on. How do I get the light to go out. Ron P. 2004 Monaco Executive Link to comment Share on other sites More sharing options...
vito.a Posted March 2, 2021 Share Posted March 2, 2021 We have a 2004 Signature. Should be identical with an HWH air leveling system. The reset button is on the drivers left side console most of the way to the rear. Link to comment Share on other sites More sharing options...
powersltc Posted March 2, 2021 Author Share Posted March 2, 2021 Thanks. I know where the button is located. It is lit. I'm trying to find out how to get it to go out and touch pad light up. Link to comment Share on other sites More sharing options...
Frank Bergamo Posted March 2, 2021 Share Posted March 2, 2021 Turn off power to coach for a few minutes. That might reset it. Hope this helps. Link to comment Share on other sites More sharing options...
powersltc Posted March 2, 2021 Author Share Posted March 2, 2021 I tried that. No luck. Thanks. Link to comment Share on other sites More sharing options...
Mocephus Posted March 2, 2021 Share Posted March 2, 2021 I have an ‘05 Signature. In the outside front run box, below the driver seat, I have an HWH reset switch. That may reset your panel. Link to comment Share on other sites More sharing options...
Mike Rizzo Posted March 2, 2021 Share Posted March 2, 2021 Hi Ronald I had the same thing happen to me last year.. I pressed every button and check every fuse and it ended up I had hit the button to raise my tag in error . That caused an error in the leveling system ... So I would check that .. might be an easy fix ... Mike 2005 Dynasty Link to comment Share on other sites More sharing options...
powersltc Posted March 2, 2021 Author Share Posted March 2, 2021 Thanks Link to comment Share on other sites More sharing options...
