Bob Keating Posted March 12, 2021 Share Posted March 12, 2021 Hi all! I am a newby here and this is my first post. My question is this, is 120 V shore power enough when storing my '09 Cayman to keep the batteries alive and power the bay heater? I can run a dedicated 30A or 50A for this, but it seems like overkill. Link to comment Share on other sites More sharing options...
Scotty Hutto Posted March 12, 2021 Share Posted March 12, 2021 Bob, I keep my coach plugged in to a 15a 120v receptacle when I’m storage. That keeps the batteries charged, residential fridge cold, and bay heater running. Now, I *wish* I had a 30a (or at least 20a) circuit so I could run the AC when I’m working on the rig, but it’s a rented space, so not an option for me. One note: if you are using the bay heater that came with the coach, it’s 12v and runs off the house battery bank. IF it runs continually the inverter/charger can struggle to keep up if you have it limited to 9a (Because of the 15a circuit)…. Ask me how I know… Hope that helps. Link to comment Share on other sites More sharing options...
Bob Keating Posted March 12, 2021 Author Share Posted March 12, 2021 Thanks! I was not aware the bay heater was 12V only. I live in Oklahoma, and the climate requires only limited use of the bay heater in the winter. I just raised my barn door, so future storage will be in an insulated barn. Link to comment Share on other sites More sharing options...
jacwjames Posted March 12, 2021 Share Posted March 12, 2021 (edited) I survived with just a 20 amp circuit for +20 years in my old house. Could not run the AC or heat while I was working on anything in the motorhome or while prepping to go on a trip. Built a new house and I went crazy I installed three 50 amp circuits, I in the garage, one mounted outside on the corner of the garage that I used while I completed the house, and then one on an RV pedestal. The RV pedestal comes in handy for visitors. I just built my garage and feed another 50 amp circuit from the RV pedestal to power the RV and a shop area. IMHO if you are going to add power at minimum I'd install a 30 amp but for the additional cost of going to 50 it would give you a lot of flexibility. Edited March 12, 2021 by jacwjames 1 Link to comment Share on other sites More sharing options...
DavidL Posted March 12, 2021 Share Posted March 12, 2021 1 hour ago, Bob Keating said: Thanks! I was not aware the bay heater was 12V only. I live in Oklahoma, and the climate requires only limited use of the bay heater in the winter. I just raised my barn door, so future storage will be in an insulated barn. and you probably know that insulation only helps if there is also a heat source inside the barn. Insulation with no heat just delays the inevitable frozen pipes. Link to comment Share on other sites More sharing options...
Ivan K Posted March 12, 2021 Share Posted March 12, 2021 10 minutes ago, DavidL said: and you probably know that insulation only helps if there is also a heat source inside the barn. Insulation with no heat just delays the inevitable frozen pipes. I have to concur with this statement after my experience with recent TX freeze. The blackouts stopped my shop oil heater and while insulated, temp inside dropped to 22F. I had to run the generator to feed an electric heater and a drop light since we were not winterized and loaded up to leave for Q as soon as the ice was gone. Never had to do it before, unexpected experience... now I have an exhaust outlet port in the shop wall. Link to comment Share on other sites More sharing options...
Bob Keating Posted March 12, 2021 Author Share Posted March 12, 2021 Thanks for all of the feed back. Should have stated that the barn also has heat. Link to comment Share on other sites More sharing options...
