moxy1962 Posted March 13, 2021 Share Posted March 13, 2021 Link to comment Share on other sites More sharing options...
Gerald H Posted March 13, 2021 Share Posted March 13, 2021 Part # and voltage ?? Link to comment Share on other sites More sharing options...
vito.a Posted March 13, 2021 Share Posted March 13, 2021 When you say older what year is it? I ask because I purchased a new reversing valve for our 2004 Dometic Penguin heat pump on eBay. Link to comment Share on other sites More sharing options...
moxy1962 Posted March 13, 2021 Author Share Posted March 13, 2021 18 minutes ago, vito.a said: When you say older what year is it? I ask because I purchased a new reversing valve for our 2004 Dometic Penguin heat pump on eBay. coach is 01 Dynasty, part number i need is 3310714005, every where I have looked is out of stock with no availablility 40 minutes ago, Gerald H said: Part # and voltage ?? 120 volt, part # 3310714005, no body seems to have stock and no date for availability Link to comment Share on other sites More sharing options...
vito.a Posted March 13, 2021 Share Posted March 13, 2021 Yes, mine uses the came coil assembly. I just looked and they are out. I guess Covid has caused lots of shortages. The part number for the solenoid coil harness is 3310714.005. Note that the valve itself is not replaceable, only the solenoid harness. Link to comment Share on other sites More sharing options...
Gerald H Posted March 13, 2021 Share Posted March 13, 2021 3 hours ago, moxy1962 said: coach is 01 Dynasty, part number i need is 3310714005, every where I have looked is out of stock with no availablility 120 volt, part # 3310714005, no body seems to have stock and no date for availability At this moment, getrvparts.com is showing in stock for $44.99 with part number you sent 4 minutes ago, Gerald H said: At this moment, getrvparts.com is showing in stock for $44.99 with part number you sent Also in RVautoparts.com shows in stock for $68.73 . Link to comment Share on other sites More sharing options...
moxy1962 Posted March 13, 2021 Author Share Posted March 13, 2021 22 minutes ago, Gerald H said: At this moment, getrvparts.com is showing in stock for $44.99 with part number you sent Also in RVautoparts.com shows in stock for $68.73 . I’m on the web site and can’t add part to cart 27 minutes ago, Gerald H said: At this moment, getrvparts.com is showing in stock for $44.99 with part number you sent Also in RVautoparts.com shows in stock for $68.73 . Could you send me the link for rvautoparts.com , searched the part number with no results 28 minutes ago, Gerald H said: At this moment, getrvparts.com is showing in stock for $44.99 with part number you sent Also in RVautoparts.com shows in stock for $68.73 . Could you send me the link for rvautoparts.com , searched the part number with no results 6 minutes ago, moxy1962 said: I’m on the web site and can’t add part to cart Could you send me the link for rvautoparts.com , searched the part number with no results Could you send me the link for rvautoparts.com , searched the part number with no results Link to comment Share on other sites More sharing options...
wamcneil Posted March 14, 2021 Share Posted March 14, 2021 I’ve got an AC for parts. Let me know if you need the solenoid. I suspect the reversing valve was this unit’s problem, but I believe the solenoid is good. Cheers Walter Link to comment Share on other sites More sharing options...
moxy1962 Posted March 14, 2021 Author Share Posted March 14, 2021 49 minutes ago, wamcneil said: I’ve got an AC for parts. Let me know if you need the solenoid. I suspect the reversing valve was this unit’s problem, but I believe the solenoid is good. Cheers Walter Can’t seem to fine one anywhere and the original one is not working, I haven put voltage to it and tested magnetism with screws driver, happy to pay for it, Link to comment Share on other sites More sharing options...
Jobert Posted March 14, 2021 Share Posted March 14, 2021 In lieu of a replacement in a timely manner, one can take some strong magnets and attach them to the reversing valve where the solenoid is located and wire tie them in place to hold open the valve. This would be a temp fix till you can locate or get a replacement coil. I was told to use this method while waiting on a replacement several years ago. It will work on AC only and not heat. Hope this may help, Happy Trails Bert 1 Link to comment Share on other sites More sharing options...
moxy1962 Posted March 14, 2021 Author Share Posted March 14, 2021 1 hour ago, Jobert said: In lieu of a replacement in a timely manner, one can take some strong magnets and attach them to the reversing valve where the solenoid is located and wire tie them in place to hold open the valve. This would be a temp fix till you can locate or get a replacement coil. I was told to use this method while waiting on a replacement several years ago. It will work on AC only and not heat. Hope this may help, Happy Trails Bert Thank you I’ll try that Link to comment Share on other sites More sharing options...
wamcneil Posted March 15, 2021 Share Posted March 15, 2021 (edited) On 3/14/2021 at 9:48 AM, moxy1962 said: Can’t seem to fine one anywhere and the original one is not working, I haven put voltage to it and tested magnetism with screws driver, happy to pay for it, Ok, got it out of the AC. Mine is 2003 dometic 630515.321 Part number on the solenoid is not legible, but looks just like this one: http://www.nwrvsupply.com/product/3310714005.html IMG_4330.HEIC Edited March 15, 2021 by wamcneil Link to comment Share on other sites More sharing options...
moxy1962 Posted March 15, 2021 Author Share Posted March 15, 2021 40 minutes ago, wamcneil said: Ok, got it out of the AC. Mine is 2003 dometic 630515.321 Part number on the solenoid is not legible, but looks just like this one: http://www.nwrvsupply.com/product/3310714005.html IMG_4330.HEIC 2.82 MB · 1 download Great will You sell it to me, Link to comment Share on other sites More sharing options...
wamcneil Posted March 15, 2021 Share Posted March 15, 2021 Sure. Send me PM with your address. Link to comment Share on other sites More sharing options...
