laurice@email.com Posted March 25, 2021 Share Posted March 25, 2021 I am looking to find a 7 day 24 hour timer to control the on/off function of our water heater and timers to be able to set different temperatures for the furnaces and air conditioners. I am looking for a system similar to the options available for a sticks and bricks heating / air conditioning systems. The heating/ac system in our coach is controlled through a Carrier IV wireless remote. Has anyone found a way to do this in their coach? Thanks Laurice & Jennifer Hermiston 2009 Monaco Knight 38 PKQ Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted March 25, 2021 Share Posted March 25, 2021 Remember that the rv is 12v and residential thermostats are 24v. The water heater will just take a 120v, 15a timer. I did the timer on the water heater. It took a homemade 12ga extension cord to put it between the outlet and the water heater plug. Gary 05 AMB DST Link to comment Share on other sites More sharing options...
laurice@email.com Posted March 25, 2021 Author Share Posted March 25, 2021 Good idea. Too bad there is nothing available for 12V configurations. Link to comment Share on other sites More sharing options...
hitechpete Posted March 26, 2021 Share Posted March 26, 2021 (edited) 17 hours ago, laurice@email.com said: Good idea. Too bad there is nothing available for 12V configurations. There is a replacement for the Dometic comfort control 1 and 2, which is touch button and I believe has timer functions for A/C and Heating, along with Bluetooth. Check on this forum, it’s about $240. Micro-Air thermostat: https://www.amazon.com/dp/B08PJZG6L4/ref=cm_sw_r_cp_apa_fabc_PCZE97HHK1RFS321M1DR?_encoding=UTF8&psc=1 Edited March 26, 2021 by hitechpete URL added Link to comment Share on other sites More sharing options...
laurice@email.com Posted March 26, 2021 Author Share Posted March 26, 2021 Thanks. Will try and find. Link to comment Share on other sites More sharing options...
hitechpete Posted March 26, 2021 Share Posted March 26, 2021 1 hour ago, hitechpete said: There is a replacement for the Dometic comfort control 1 and 2, which is touch button and I believe has timer functions for A/C and Heating, along with Bluetooth. Check on this forum, it’s about $240. Micro-Air thermostat: https://www.amazon.com/dp/B08PJZG6L4/ref=cm_sw_r_cp_apa_fabc_PCZE97HHK1RFS321M1DR?_encoding=UTF8&psc=1 Link to comment Share on other sites More sharing options...
laurice@email.com Posted March 26, 2021 Author Share Posted March 26, 2021 Thanks. Really appreciated. Will check it out. Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted March 26, 2021 Share Posted March 26, 2021 Could this Hutch Mountain thermostat replace the 5 button thermostat in my 05 Ambassador? It sounds like a simple replacement instead of going to a 7 button. Gary 05 AMB DST Link to comment Share on other sites More sharing options...
Larry Laursen Posted March 27, 2021 Share Posted March 27, 2021 Look at this for your water heater. Just replace the switch at your power control panel. JVR 12V Timer Switch Programmable Digital 12 Volt DC/AC/Solar Battery Powered - - Amazon.com Link to comment Share on other sites More sharing options...
Scotty Hutto Posted March 28, 2021 Share Posted March 28, 2021 On 3/26/2021 at 9:56 AM, Gary 05 AMB DST said: Could this Hutch Mountain thermostat replace the 5 button thermostat in my 05 Ambassador? It sounds like a simple replacement instead of going to a 7 button. Gary 05 AMB DST I believe so. They have several variations depending on what you have in your coach now. Since your coach is similar vintage to mine, look at this one I configured for my coach: Model: EasyTouch RV 357Part Number: ASY-357-X01Color: Black Laurice, I believe they have configurations for Coleman units also. https://www.hutchmountain.com/products/micro-air-easytouch-rv-thermostat Link to comment Share on other sites More sharing options...
amphi_sc Posted March 28, 2021 Share Posted March 28, 2021 Gary, I recently picked up one to try as the new CCC2 is too big for my wall space where the original front thermostat is mounted. Hopefully it will function as advertised and DW can read the icons. BTW, unless I decide to keep it (them) as a "just in case" spare for a while, I will be removing that 5 button thermostat, and I have compatible 5 button control boards for both the new penguin II HP as well as vintage penguin HP as I just swapped in a new HP because of a compressor lockup failure in the old unit. (In case someone might need a part.). Or if I don't like the microair after trying it for a while, then that would be available instead... Link to comment Share on other sites More sharing options...
