Steve Hepfer Posted April 28, 2021 Share Posted April 28, 2021 Can anyone explain how to replace the drain line for the front dash ac? I think mine may be plugged causing a leak inside on the floor at the bottom of the return grille. Thx Link to comment Share on other sites More sharing options...
DavidL Posted April 28, 2021 Share Posted April 28, 2021 You can use compressed air to blow the blockage in Link to comment Share on other sites More sharing options...
Steve Hepfer Posted April 28, 2021 Author Share Posted April 28, 2021 If that doesn't work and I have to replace the hose not sure how to remove the apparent obstruction in front of it. Looks like it could be a vacuum of some type Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted April 29, 2021 Share Posted April 29, 2021 try running a coat hanger up the drain. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
vanwill52 Posted April 29, 2021 Share Posted April 29, 2021 A wet/dry vac with cobbled-up adapter can sometimes clear a clog. Worked for me on the AC roof drains. Link to comment Share on other sites More sharing options...
Rikadoo Posted April 30, 2021 Share Posted April 30, 2021 Bad thing about a plugged evaporator drain is the mildew smell🤢 hope you get it fixed soon. Link to comment Share on other sites More sharing options...
Steve Hepfer Posted May 1, 2021 Author Share Posted May 1, 2021 I took the drain tube off but didn't find any blockage. I will keep the dash air off going to our next stop and see if it stays dry. Then run the dash air again the following stop and check it again Link to comment Share on other sites More sharing options...
redstickbill Posted May 3, 2021 Share Posted May 3, 2021 Sometimes the outside door gasket will fail and allow ambient air to enter when running the A/C on Max, this will cause condensation to gather and can get the floor wet on the passenger side. Had that problem in a 2002 Diplomat. Bill B 07 Dynasty Link to comment Share on other sites More sharing options...
