WayneC Posted May 1, 2021 Share Posted May 1, 2021 Thought I would share the out come of the Aqua hot trouble shooting escapade! Thought I better document this for future reference hopefully it may help someone else out. Started off with no power getting to the unit, opened the front drivers side panel outside and checked 12 volt fuse aqua hot, good, took the cover off the Aqua hot and the ignition fuse far right 10 amp,blown! , tried it again and blew again, Ivan mentioned to test power at the plug C5 and C8 and we had power (electronic control unit) took complete unit out and the fuel solenoid 12volt wires were broken away from the plastic and you could see inside the solenoid, ordered a new one and a new burner motor,it was the original motor (Black) new ones are silver, Put the new parts in , new fuse turned it on and nothing. Started process off elimination, unplugged motor ,unplugged coil and turned it on ,fuse was good, plugged in coil turned it on and blew the fuse, the wire under the coil must be original as well and was broken/cracked, fixed it up hopefully it will last for a few more years. Aqua hot running great, all zones working. I do have a question in regards to the front thermostat, at times it will power up other times just stubborn, I have a newer one 5 button that I put on the phone cable and it will say err and then put the old one back on and way we go, seems like the signal is weak or what ? Any help be appreciated, I have read so many threads on this all over the internet not sure what to believe at this point. Thanks Wayne 1999 Signature Caesar Link to comment Share on other sites More sharing options...
John Haggard Posted May 1, 2021 Share Posted May 1, 2021 (edited) Annual inspection Annual service is so critical Getting on Roger's forum is a great learning experience 👌 Roger Burk hydrohot Over the past 15 years I have sent him my burner for a complete tear down and re build Two times When I purchased my coach with 50,000 miles it was lacking in professional maintenance 😒 Like my spare rebuilt Alternator I carry a spare neweley rebuilt burner and silver box. Enjoy your aquahot and I'm so glad you got it going. Edited May 1, 2021 by John Haggard Details left out 1 Link to comment Share on other sites More sharing options...
WayneC Posted May 1, 2021 Author Share Posted May 1, 2021 Thanks John 1 Link to comment Share on other sites More sharing options...
Tim-AZ Posted May 1, 2021 Share Posted May 1, 2021 (edited) 29 minutes ago, wayne.cerven@gmail.com said: Thanks John On your new thermostat did you reset it after plugging in the phone cable? You do that by Plugging it in, Turn it off, Push in the top and bottom buttons at the same time and turning it on while holding the two buttons in and then release the buttons. You should see FF in the screen. Then just turn on the mode you want. Tim Edited May 1, 2021 by Timaz996 Link to comment Share on other sites More sharing options...
Dr4Film Posted May 1, 2021 Share Posted May 1, 2021 Regarding the CCC Thermostat, I would clean up all of the contacts with contact cleaner and possibly change out the RJ-11 connectors on each end of the data cables with new ones. Link to comment Share on other sites More sharing options...
WayneC Posted May 1, 2021 Author Share Posted May 1, 2021 Thanks Richard Will try that tomorrow. 28 minutes ago, Timaz996 said: On your new thermostat did you reset it after plugging in the phone cable? You do that by Plugging it in, Turn it off, Push in the top and bottom buttons at the same time and turning it on while holding the two buttons in and then release the buttons. You should see FF in the screen. Then just turn on the mode you want. Tim Yes I did try that in the past, just not getting power to the thermostat at times Thanks Wayne Link to comment Share on other sites More sharing options...
Megame Posted May 1, 2021 Share Posted May 1, 2021 Not quite on topic, but what did your new burner motor cost? Link to comment Share on other sites More sharing options...
WayneC Posted May 1, 2021 Author Share Posted May 1, 2021 $ 700.00 cnd for the motor, and $ 400.00 cnd for the solenoid included 2 shipping right to the house. Link to comment Share on other sites More sharing options...
Megame Posted May 1, 2021 Share Posted May 1, 2021 Wayne, thanks for your reply. Can these motors be rebuilt? It sounds like a bearing is going on mine. And could you give me the name and address of your supplier for the motor as well please! Link to comment Share on other sites More sharing options...
WayneC Posted May 1, 2021 Author Share Posted May 1, 2021 Just now, Megame said: Wayne, thanks for your reply. Can these motors be rebuilt? It sounds like a bearing is going on mine. And could you give me the name and address of your supplier for the motor as well please! The one I pulled out was a Bosch, the new one had a German name on it, never thought to write it down. I don't believe so but again never thought to ask him. Supplier- Alberta Coach and Chassis Ltd, Steve Horseman , 780 998 2736, first time dealing with him, seemed very knowledgeable, 20 years of servicing. It was cheaper quicker then Aqua hot tthemselves (USA) Wayne Just now, wayne.cerven@gmail.com said: The one I pulled out was a Bosch, the new one had a German name on it, never thought to write it down. I don't believe so but again never thought to ask him. Supplier- Alberta Coach and Chassis Ltd, Steve Horseman , 780 998 2736, first time dealing with him, seemed very knowledgeable, 20 years of servicing. It was cheaper quicker then Aqua hot tthemselves (USA) Wayne Hulsemann , phone with auto correct! Never thought to ask about a rebuild Link to comment Share on other sites More sharing options...
Megame Posted May 1, 2021 Share Posted May 1, 2021 Thanks Wayne, much appreciated. I am in Ontario, but now have a contact in Canada. That helps! Stay safe! Link to comment Share on other sites More sharing options...
Corkman Posted May 2, 2021 Share Posted May 2, 2021 15 hours ago, John Haggard said: Do you have the link to the Aqua Hot Forum? I tried "http://www.forum.rvhydronicheaterrepair.com/" but get the error "This site can’t be reached" Link to comment Share on other sites More sharing options...
John Haggard Posted May 2, 2021 Share Posted May 2, 2021 33 minutes ago, Corkman said: No Sorry But someone will chime in with it. We are on the lake fishing this weekend 😎 No computer Link to comment Share on other sites More sharing options...
Paul A. Posted May 2, 2021 Share Posted May 2, 2021 3 hours ago, Corkman said: Go to; rogerberke.com It will give you an option to join his forum. Link to comment Share on other sites More sharing options...
miacasa_2000 Posted May 2, 2021 Share Posted May 2, 2021 Wayne My unit was acting up like that and I found the other end of that (phone cable) goes up to the ac first and the couplers on mine were all corroded. After all ends cleaned and new couplers the gremlins stopped. Roy Mercier 2003 Dynasty Link to comment Share on other sites More sharing options...
WayneC Posted May 2, 2021 Author Share Posted May 2, 2021 2 hours ago, miacasa_2000 said: Wayne My unit was acting up like that and I found the other end of that (phone cable) goes up to the ac first and the couplers on mine were all corroded. After all ends cleaned and new couplers the gremlins stopped. Roy Mercier 2003 Dynasty Thanks Roy,I will open the cover on the ceiling and clean all ends. Amazing what the gremlins can do over couple months. Wayne 1999 Signature Caesar Link to comment Share on other sites More sharing options...
Corkman Posted May 3, 2021 Share Posted May 3, 2021 6 hours ago, Paul A. said: Go to; rogerberke.com It will give you an option to join his forum. Hi Paul, Have you been able to get to the forum? I followed a link via http://www.rogerberke.com/) but the forum link does not work, nor the "contact me" link. Link to comment Share on other sites More sharing options...
Dr4Film Posted May 3, 2021 Share Posted May 3, 2021 (edited) The link that I use to get to Roger Berke's Aqua-Hot Forum where you can sign up at is: http://forum.rvhydronicheaterrepair.com/content.php The other link should have worked also so I don't know what your specific problem might be other than to clean up your cache and get rid of excess files in your browser or try a different browser. I use FireFox. Edited May 3, 2021 by Dr4Film 1 Link to comment Share on other sites More sharing options...
Corkman Posted May 3, 2021 Share Posted May 3, 2021 4 hours ago, Dr4Film said: Perfect, thanks Link to comment Share on other sites More sharing options...
Paul A. Posted May 3, 2021 Share Posted May 3, 2021 15 hours ago, Corkman said: Hi Paul, Have you been able to get to the forum? I followed a link via http://www.rogerberke.com/) but the forum link does not work, nor the "contact me" link. Try this link; http://rvhydronicheaterrepair.com/ The menu is near the top. Click on ; forum. Link to comment Share on other sites More sharing options...
Corkman Posted May 3, 2021 Share Posted May 3, 2021 26 minutes ago, Paul A. said: Try this link; http://rvhydronicheaterrepair.com/ The menu is near the top. Click on ; forum. this link below worked great, thanks http://forum.rvhydronicheaterrepair.com/content.php Link to comment Share on other sites More sharing options...
