Hypoxia Posted May 4, 2021 Share Posted May 4, 2021 Does anyone with a 3D printer make the Anemometer plastic piece? All of the replacement cups I have seen are very fragile. The Girard blade type is less fragile but doesn't seem to move with a small amount of wind. I have not found any of the blade type replacements. Link to comment Share on other sites More sharing options...
pwhittle Posted May 4, 2021 Share Posted May 4, 2021 (edited) The cups on arms with a center hub is an awkward shape to 3D print without supports. I expect to we could come up with a multi-piece design that would be easier to print. I have a spare I can try to model it off. now that I liked, there are many designs to use as inspiration here. https://www.thingiverse.com/search?q=Anemometer&type=things&sort=relevant Paul Edited May 4, 2021 by pwhittle Link to comment Share on other sites More sharing options...
planodp Posted May 4, 2021 Share Posted May 4, 2021 I'm sure Paul will come up with something to replace it with. Count me in on this to Paul. Link to comment Share on other sites More sharing options...
Paul A. Posted May 4, 2021 Share Posted May 4, 2021 Cut a ping pong ball in half. It works. Good luck if you depend on that devise to save your awning. We full timed 10 years and most full timers never depended on them. Any sudden wind blast will do damage before the devise can actuate fast enough to retract the awnings. Take a watch and time how long it takes for a large patio awning to retract. 1 Link to comment Share on other sites More sharing options...
Terry T Posted May 4, 2021 Share Posted May 4, 2021 Paul, can the 3d printer do the window weep hole covers? terry Link to comment Share on other sites More sharing options...
Hypoxia Posted May 4, 2021 Author Share Posted May 4, 2021 They are mainly for when I don't realize the steady wind is increasing or forget they are out. I rarely put the fragile Girard patio awnings out, one $500 wind gust taught me that lesson & it was a small gust. Has anyone tied the Girard awnings down? Seems like a lasso at each end might work. Link to comment Share on other sites More sharing options...
pwhittle Posted May 4, 2021 Share Posted May 4, 2021 4 hours ago, Terry T said: Paul, can the 3d printer do the window weep hole covers? terry Yes, I am sure they can. I am not sure it is economical to do it that way rather than just buy them from Atwood though unless you are doing it for yourself. Paul Link to comment Share on other sites More sharing options...
