a4epilot Posted May 9, 2021 Share Posted May 9, 2021 Can't find the fuse for my trailer plugin socket. Found fuses for all the exterior lights, etc. in the electrical run bay under drivers seat. There is no other place to look that I can think of. Wondering if it is an inline fuse somewhere where it will be impossible to locate without someone pointing me in the right direction. Thanks in advance. Gary K 06' Windsor Link to comment Share on other sites More sharing options...
Hardy1000 Posted May 9, 2021 Share Posted May 9, 2021 On my 07 Diplomat the fuses are in the rear curb side bay. My inverter is also located in that bay. Link to comment Share on other sites More sharing options...
waterskier_1 Posted May 9, 2021 Share Posted May 9, 2021 Which specific light fuse are you looking for? Turn Signal? Brake? Marker (Running)? +12 VDC Power? There is not a single fuse that supplies all circuits in the trailer connector. Link to comment Share on other sites More sharing options...
John Haggard Posted May 9, 2021 Share Posted May 9, 2021 See if you have a single wire running to the panel where your big boy is. Is there a single wire ? Wired hot with a 10 amp fuse down 10 to 14 inches heading toward a spliter ? That feeds the back of your plug ??? Look around I blew that fuse and lost all 12 volt to my trailer 7 way plug. Link to comment Share on other sites More sharing options...
a4epilot Posted May 9, 2021 Author Share Posted May 9, 2021 15 minutes ago, waterskier_1 said: Which specific light fuse are you looking for? Turn Signal? Brake? Marker (Running)? +12 VDC Power? There is not a single fuse that supplies all circuits in the trailer connector. Good point! Looking for 12 VDC power fuse. The other wires you mentioned are probably simply and extension of the same ones for the coach and are covered by their fuses. Link to comment Share on other sites More sharing options...
waterskier_1 Posted May 9, 2021 Share Posted May 9, 2021 Ok. On my 05 Exec, it is in the Rear Run Bay. It is NOT a fuse, but an automatic reset circuit breaker. New RRB.pdf Link to comment Share on other sites More sharing options...
Dr4Film Posted May 9, 2021 Share Posted May 9, 2021 I might as well add my two cents too. There is no fuse for the trailer plug. However there are fuses for each function within the trailer plug such as brake lights, turn signals, running lights, and perhaps a charge wire too. I would doubt very much that all of these functions have blown fuses so I would imagine that something else is going on that if you explain in a follow-up post we would be able to assist you to solving the problem. Link to comment Share on other sites More sharing options...
granvillebarker Posted May 10, 2021 Share Posted May 10, 2021 Mine is on a fuse labeled unused in the rear run box, it’s on a board to the left of the big boy. Link to comment Share on other sites More sharing options...
a4epilot Posted May 10, 2021 Author Share Posted May 10, 2021 On 5/9/2021 at 11:53 AM, a4epilot said: Can't find the fuse for my trailer plugin socket. Found fuses for all the exterior lights, etc. in the electrical run bay under drivers seat. There is no other place to look that I can think of. Wondering if it is an inline fuse somewhere where it will be impossible to locate without someone pointing me in the right direction. Thanks in advance. Gary K 06' Windsor Thank you all very much for your answers. Found what I needed to know. Gary K Link to comment Share on other sites More sharing options...
