powersltc Posted June 10, 2021 Share Posted June 10, 2021 Ton P., 2004 Monaco Executive Hello. Has anyone had the pleasure of changing out a sofa? I have a J-Lounge soda that I would like to exchange but it has a heat exchange vent in it. I have called Villa but no return calls. Any ideas/suggestions would be Appreciated. Link to comment Share on other sites More sharing options...
Lackey Posted June 10, 2021 Share Posted June 10, 2021 We had ours reupholstered. Turned out great! Link to comment Share on other sites More sharing options...
vito.a Posted June 10, 2021 Share Posted June 10, 2021 I've removed and reinstalled both of our couches when updating the carpet. On our coach, the one on the passenger side has the Aqua Hot heat exchanger. First remove the drawers under the couch and then you will see the retaining screws into the floor. I used a 90 degree cordless drill to remove the retaining screws. Once you remove the couch you will see the Aqua Hot heat exchanger. You should be able to relocate it, but you will be limited in how far you can move it because of the Aqua Hot hoses. I guess you could add new longer hoses, but they would need to be covered for aesthetics. Link to comment Share on other sites More sharing options...
Ernie Ekberg Posted June 10, 2021 Share Posted June 10, 2021 The heat exchanger can be moved, mounted elsewhere or eliminated- if you don’t need it. Link to comment Share on other sites More sharing options...
Dennis H Posted June 11, 2021 Share Posted June 11, 2021 I guess the first thing would be to decide what you'd like to put in it's place. Reupholstery shops can do wonders to 'upgrade' your lounger. I use mine all the time and wouldn't hesitate to have it redone. We use that aqua hot as much as the overhead heat pumps.....Dennis Link to comment Share on other sites More sharing options...
planodp Posted June 11, 2021 Share Posted June 11, 2021 I have the same problem. I have the same year and model as powersltc. I want to install J-Lounge and can't find one that will fit in the spot. The floor is not straight across on the slide out. Link to comment Share on other sites More sharing options...
