Gary Cole Posted July 6, 2021 Posted July 6, 2021 There was an interesting topic on another forum discussing a new owners complaint that his ISL 400 Cummins lacked power when climbing steep grades. Not being a member I didn't comment. However, I was surprised at the number of people who recommended that he approach grades at full rpm with pedal to the metal and keep it that way during the entire climb. Perhaps gaining a minute or two in the process. Not to mention consuming fuel like he had a hole in his tank. My comment would have been that making a habit of operating a diesel engine in that manner would be the best diagnostic tool available if one was intent on eventually discovering a hidden, potentially catastrophic, weakness in an engine or transmission. A flaw which otherwise might have remained unknown for the life of the coach.
Rick A Posted July 6, 2021 Posted July 6, 2021 Wow, that’s silly. How about just going down a gear, and maintaining speed with a few more revs. Amazingly that’s what Allison tranny recommend. isn’t that what gears are for? What am I missing?
Wesley Pool Posted July 6, 2021 Posted July 6, 2021 That is really unfortunate. As we all know, bad advice is always worse than no advice. I agree with Rick A. Gears?
Dr4Film Posted July 6, 2021 Posted July 6, 2021 I guess you guys must travel a lot in Florida where the highest elevation is maybe 350 feet above sea-level. I have climbed many mountains both east and west of the Rockies, Canadian Rockies, all through Alberta, British Columbia, Yukon and Alaska and there have been many times that to keep the engine revving at about 2000 rpm's it requires that the fuel treadle be completely at the maximum. This has been while hauling a 30 foot 11,000 lb cargo trailer too. There is one mountain that we climbed in Jasper National Park on the Ice Fields Parkway on our way to the Columbia Ice Field where I was at full throttle climbing at 12 mph in first gear for over 3 minutes. I defy any one with an ISB or ISC to not climb that mountain towing anything without having your pedal to the floor. For those exact road conditions is why I highly recommend having an Exhaust Temperature Gauge (EGT) to monitor the temp making sure that it stays below 1250F. 2 1
Soybean Posted July 6, 2021 Posted July 6, 2021 Some information posted here at times is. wives tales. Diesel engines are designed to be used. If anyone has set at a construction site and watched they would see lots of equipment runs wide open all day long, big generators or water pumps may run that way for months at a time. When a 250000 generator runs that way it is hard to believe running wide open hurts them. Farm equipment is used the same way. Ask a good diesel mechanic what is the hardest thing on a diesel engine. If he really knows he will say idling for long periods of time. Have been heavy equipment mechanic for 40 years so have a little knowledge about diesels
Gary Cole Posted July 7, 2021 Author Posted July 7, 2021 (edited) I wasn't suggesting that our engines were not capable of full throttle operation. I routinely use full throttle when passing or climbing a short grade when I feel that more power would prevent a downshift. Transmission downshifts are not entirely free of wear and tear. Many years ago I was contemplating the purchase of a new truck with a Detroit 8V 92 engine. Detroit provided a spreadsheet which showed that the engine, when set at full rated horsepower, had a 40% shorter mean time between overhauls than when the engine was set at its lowest factory horsepower and rpm setting. In those days overhauls typically meant mean time between catastrophic failures such as broken crankshafts, dropped valves, piston separation, broken rods sticking through blocks, etc. Diesel engines have come a long way since then. I agree with Richard that a pyrometer is a good indicator of engine load and added one to my rv. I also use an engine oil temperature gauge as it indicates the real long term operating temp of the engine and whether it is tracking up or down. Edited July 7, 2021 by Gary Cole
Ivylog Posted July 7, 2021 Posted July 7, 2021 Lugging a turbo Diesel engine is harder on it than keeping the rpms close to the max. Exhaust gas temps will be higher and your cooling will be less at lower rpms. Only in the RV world is babying a Diesel engine the thing to do.
96 EVO Posted July 7, 2021 Posted July 7, 2021 Hi RPM's doesn't nessesarily mean full throttle. I have a 400 ISL, and climb many mountain grades in 3rd gear, 2000 rpm's, and boost pressure about 25in. If I shifted to 4th, my rpm's would be in the 1500 range, but my boost pressure may be up around 33in. So, which gear is easier on the drivetrain, and burning less fuel.
Dr4Film Posted July 7, 2021 Posted July 7, 2021 (edited) Going up the mountain, down shift to whatever gear is needed to keep your diesel engine running at the best RPM for power which should be in the range of 1800-2500 RPM's depending on your engine. That will give you the best power band. There have been only a few grades I have traveled where I've been all the way down to first gear to keep the rpm's at peak power. However most only require going down to 3rd or 4th gear. I keep my Cummins ISC-350 right around 2000 rpm's regardless of what the boost pressure gauge displays. The tach is your friend and what you need to monitor not the boost pressure. Edited July 7, 2021 by Dr4Film 1
FishAR Posted July 7, 2021 Posted July 7, 2021 2 hours ago, Dr4Film said: Going up the mountain, down shift to whatever gear is needed to keep your diesel engine running at the best RPM for power which should be in the range of 1800-2500 RPM's depending on your engine. That will give you the best power band. There have been only a few grades I have traveled where I've been all the way down to first gear to keep the rpm's at peak power. However most only require going down to 3rd or 4th gear. I keep my Cummins ISC-350 right around 2000 rpm's regardless of what the boost pressure gauge displays. The tach is your friend and what you need to monitor not the boost pressure. This is something that confuses me. Doesn't the Allison take care of that? I've got a paddle shifter on my 2018 Ram 6.7 cummins/aisin dually but I've never used it. I've read lots of people on ram forums talk about how useful it is. My biggest climb has been Monteagle loaded with 16,500 lb fifth wheel and I just let the tranny shift itself. I know the Monaco weighs a lot more, also mine has a lot larger engine, so maybe not apples to apples but it would seem the allison would be designed to keep it in the acceptable rpm range.
96 EVO Posted July 7, 2021 Posted July 7, 2021 3 hours ago, Dr4Film said: Going up the mountain, down shift to whatever gear is needed to keep your diesel engine running at the best RPM for power which should be in the range of 1800-2500 RPM's depending on your engine. That will give you the best power band. There have been only a few grades I have traveled where I've been all the way down to first gear to keep the rpm's at peak power. However most only require going down to 3rd or 4th gear. I keep my Cummins ISC-350 right around 2000 rpm's regardless of what the boost pressure gauge displays. The tach is your friend and what you need to monitor not the boost pressure. The reason I mentioned the turbo boost pressure is to show that higher RPM's doesn't necessarily equate to higher fuel consumption.
Chuck B 2004 Windsor Posted July 7, 2021 Posted July 7, 2021 Keep in mind that Allison considers their transmission in a motor home as LIGHT duty usage. Chuck B 2004 Windsor
Dr4Film Posted July 8, 2021 Posted July 8, 2021 21 hours ago, FishAR said: This is something that confuses me. Doesn't the Allison take care of that? I know the Monaco weighs a lot more, also mine has a lot larger engine, so maybe not apples to apples but it would seem the Allison would be designed to keep it in the acceptable rpm range. If traveling on flat terrain the Allison will shift at approximate speed points not necessarily rpm's. After climbing and descending hundreds of grades I have learned important speed and rpm points on MY Allison and ISC-350 combination. When climbing a steep grade the rpms's and your speed will degrade quickly. If you don't keep the rpm's in the 2000 range you are lugging the engine with not enough power. My Allison is always late to the party and such will drop to 1500 quickly whereas the speed may still be within the range that the Allison still likes therefore will not downshift to raise the rpm's for more power. I manually downshift once I see the rpm's starting to drop below 1800 with a lot more grade ahead. 2
Ivylog Posted July 8, 2021 Posted July 8, 2021 (edited) A Dynasty with a ISL-3000 Alison has a 4.78 axle ratio while the rigs with a 4000 Alison have a 4.33 ratio. When climbing with a ISL I’d keep the rpm above 1800 and now with a ISX it’s 1650 which equals 65mph in 6th on the flat. Agree a fuel leak ^^^ after working on the turbo doesn’t add up…not sure the two were related. If I’d worked on your turbo I wouldn’t pay for a fuel leak. Edited July 8, 2021 by Ivylog
dandick66 Posted July 9, 2021 Posted July 9, 2021 I’ve been following this thread with interest. I have a 2012 Diplomat with the Maxxforce 10. The torque is rated at 1250 lbs/ft at 1300 RPM and 405 HP at 2000 RPM. I’ve driven primarily on the east coast. The biggest mountains/hills here are nothing like those out west. The biggest one near me is Afton Mountain on 64 near Charlottesville, VA. There are some decent mountains in Pennsylvania while going to NY. Should I be driving for max HP or max torque? Dan D
Guest Ray Davis Posted July 9, 2021 Posted July 9, 2021 Sometimes when I leave it up to the auto transmission. it can't make up its mind. It will shift down then back up and may do that repeatedly. That can't be good for it and it runs me crazy. So that's one reason I will down shift even though the coach will make it up the hill with out me down shifting.
Chuck B 2004 Windsor Posted July 9, 2021 Posted July 9, 2021 "Sometimes when I leave it up to the auto transmission. it can't make up its mind. It will shift down then back up and may do that repeatedly."------You are putting a lot of stress on the transmission by unlocking and then locking up the torque converter. Chuck B 2004 Windsor
Dr4Film Posted July 9, 2021 Posted July 9, 2021 1 hour ago, dandick66 said: I’ve been following this thread with interest. I have a 2012 Diplomat with the Maxxforce 10. The torque is rated at 1250 lbs/ft at 1300 RPM and 405 HP at 2000 RPM. I’ve driven primarily on the east coast. The biggest mountains/hills here are nothing like those out west. The biggest one near me is Afton Mountain on 64 near Charlottesville, VA. There are some decent mountains in Pennsylvania while going to NY. Should I be driving for max HP or max torque? Dan, when climbing a grade use HP/RPM's. Remember, power is your friend not torque. 47 minutes ago, Ray Davis said: Sometimes when I leave it up to the auto transmission. it can't make up its mind. It will shift down then back up and may do that repeatedly. That can't be good for it and it runs me crazy. So that's one reason I will down shift even though the coach will make it up the hill with out me down shifting. When my Allison starts hunting on rolling to moderate grades I always downshift to a gear that it will stay at. It's easier on the transmission. 3
Guest Ray Davis Posted July 9, 2021 Posted July 9, 2021 24 minutes ago, Dr4Film said: When my Allison starts hunting on rolling to moderate grades I always downshift to a gear that it will stay at. It's easier on the transmission. That's what I was trying to say, thanks for clearing it up. LOL
Guest Ray Davis Posted July 9, 2021 Posted July 9, 2021 2 hours ago, John Haggard said: Did you try efficiency mode 🤔 On gently rolling hills I like.. Yes, I use mode most of the time on the open hiway.
96 EVO Posted July 9, 2021 Posted July 9, 2021 2 hours ago, Chuck B said: "Sometimes when I leave it up to the auto transmission. it can't make up its mind. It will shift down then back up and may do that repeatedly."------You are putting a lot of stress on the transmission by unlocking and then locking up the torque converter. Chuck B 2004 Windsor Not to mention heat in the tranny fluid!
Rick A Posted July 9, 2021 Posted July 9, 2021 Any engine that’s “under reviving” under load is being stressed. Torque is, the load transmission feeding back into the engine and this stress should be answered with revs. Under-reving is blowing fuel out the exhaust not to mention other damaged being caused. Revs are the response to the torque being applied to the engine. The way to deal with the torque which is “power demanded by the load” is revs. If the revs are not responding then down shift to increase revs. This maintains the speed and keeps the torque rev ratio in sync. Revs are your friend. Torque is your enemy, if left unchecked it will stress the engine and the result is the rev counter drop even when the peddle is being depressed. I have an ISL 400 with the Allison 3000 and I can depress the pedal quickly and it will down change on its own but I prefer to force a down gear manually. I often pass other units because their drivers haven’t figured out the “happy zone”. Tell me if I’m wrong please. 2
Rick A Posted July 9, 2021 Posted July 9, 2021 2 minutes ago, John Haggard said: Your correct And a Peddle to the metal not only throws fuel out the exhaust 🤫 It ( can ) under certain conditions destroy the proper lubing of the cylinder s and rings. We are not driving gas powered car's. I agree let’s not baby the engine, (thinking revs are harmful) and kill the entire power train with uncontrolled torque. When speed and load demand attention answer with engine power!
Ivylog Posted July 9, 2021 Posted July 9, 2021 “It ( can ) under certain conditions destroy the proper lubing of the cylinder s and rings.” Not even on your 99 Sig which will not puff black smoke because of modern electric controls. 1
Gary Cole Posted July 9, 2021 Author Posted July 9, 2021 An engineer for Mack Truck wrote an interesting article regarding the development of Mack's Maxidyne engine some years ago. The Maxidyne was the forerunner of today's modern high torque rise diesel engines. Mack used a reliable low torque rise 6 cylinder engine as a test block for the new engine. The Maxidyne operated at 1200 rpm on the low end with a torque rise of nearly 40% at that low rpm as I recall from the article. I was lucky enough to have driven one of the earlier trucks. Very impressive experience. He said that the failures, some of which occurred in minutes, included stretched head bolts, broken/bent crankshafts, bent rods, fractures in the engine block, and transmission housings which split down the middle. Mack was forced to develop a new triple shaft transmission as no single shaft transmission of the day was capable of handling the low rpm torque. This was before engine computer control and when engineers were required to do very complicated stress analysis calculations with slide rules, pencil, and paper. Today's stress analysis software based on finite elements and graphical representations would have been considered from another world at the time.
