Dennis Y Posted September 12, 2021 Share Posted September 12, 2021 I discovered that my fuel tank is leaking. The leak is cracked at the toe of the weld attaching one of the angle iron mounting tabs. I am thinking about removing the tank to have it welded. Has anyone done this? Is there anything I should know? How much does it weigh, can two people man-handle a mostly empty tank out of the drivers side? Dennis Yeats 2004 HR Ambassador Link to comment Share on other sites More sharing options...
gdroberson Posted September 12, 2021 Share Posted September 12, 2021 I used a motorcycle jack to lower mine and raise it not to bad if you get most of the fuel out Link to comment Share on other sites More sharing options...
Dennis Y Posted September 13, 2021 Author Share Posted September 13, 2021 Mine does not look like it can be lowered. It is setting in an angle iron frame with a couple of bars below the tank. Everything appears to be welded. Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted September 13, 2021 Share Posted September 13, 2021 You will be lucky to find a welder who would weld on a fuel tank. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
Dennis Y Posted September 13, 2021 Author Share Posted September 13, 2021 What are my other options? Link to comment Share on other sites More sharing options...
klcdenver Posted September 13, 2021 Share Posted September 13, 2021 .You can just weld it in place. Disconnect all batteries and place welder ground close to where it needs repaired. Open fuel cap and run a car exhaust to it running with a semi enclosed hose. After about 30 minutes it should be pretty warm and you can weld on it. Talk to a few welding shops in your area and I am sure you can find one that knows how to do it this way. If you are scared to have it welded on. Another solution is to use an epoxy steel product by JB Weld where you clean the area and just press it in place even with a leaking area. 1 Link to comment Share on other sites More sharing options...
WayneC Posted September 13, 2021 Share Posted September 13, 2021 JB weld or find a place that sells spill kits for fuel and they will have an amazing sealant that works fantastic, we use it on tanker trucks/ skid tanks for the back of pick up trucks (contractors) for portable fueling, it can be leaking and this stuff will stop it. Wayne 1999 Signature Caesar Link to comment Share on other sites More sharing options...
Yoaks5 Posted September 14, 2021 Share Posted September 14, 2021 I had a leaking fuel tank on another coach and tried a couple different epoxy type repairs with no luck. They stopped it for awhile but in the end it started leaking again (the last one on the day the new owner came to pick up the coach). I was able to find a shop that would weld it but I had to remove the tank and take it to him. Link to comment Share on other sites More sharing options...
dl_racing427 Posted September 15, 2021 Share Posted September 15, 2021 The problem with the epoxy stuff is it doesn't stop the crack from propagating. It might work better if you drill a small hole at the end of the crack to relieve the stress riser. This should be done whether epoxying or welding. Link to comment Share on other sites More sharing options...
Ivylog Posted September 15, 2021 Share Posted September 15, 2021 If you are in a rural area…farming, I would find a repair shop and see if they would weld on it in place assuming you can get a rod to the crack. After leaning the coach so no diesel is on that side and gassing it like Ken suggested, I would weld on it in place. 1 Link to comment Share on other sites More sharing options...
Paul J A Posted September 15, 2021 Share Posted September 15, 2021 (edited) On 9/12/2021 at 5:29 PM, Dennis Y said: I discovered that my fuel tank is leaking. The leak is cracked at the toe of the weld attaching one of the angle iron mounting tabs. I am thinking about removing the tank to have it welded. Has anyone done this? Is there anything I should know? How much does it weigh, can two people man-handle a mostly empty tank out of the drivers side? Dennis Yeats 2004 HR Ambassador Here is a site that you can go to, to calculate the approximate weight of the tank.https://www.chapelsteel.com/weight-steel-plate.html Many fuel tanks where/are weld repaired in the Military. Also construction equipment repair Co.'s do it all the time. Ask around at TRUCK repair shops. I would not patch it. Edited September 15, 2021 by Paul A. grammer. Link to comment Share on other sites More sharing options...
