tact50 Posted September 24, 2021 Posted September 24, 2021 My son and I have discovered in our 1994 Monoco Dynasty that there is a fluid leak coming from the power steering hose #IC40710 (diagnosed at Cummins) who did not have time to fix it. They sent us down the road ( in Milwaukee, Wi) to Truck Country. They are having trouble finding the part (hose). They mentioned maybe the trouble they are having finding the hose is ours in NOT a freightlinner chassis. I believe we have a RoadMaster chassis, and don't know how to help them track down this much needed hose (Part# IC40710 )We are hoping for suggestions or ideas?! My email address is [email protected] or my phone numbers are 414-232-6380 or 414-332-3322 if appropriate. My name is Ted. Thank you.
JetAburner Posted September 24, 2021 Posted September 24, 2021 If you can locate a hydraulic supply shop, they should be able to make one. That's how we did it on big rigs all the time. Should be one in Milwaukee. 1
Bandit411 Posted September 24, 2021 Posted September 24, 2021 You might check with a parts store like Napa some of them are capable to make hydraulic hoses. 1
Romeo84 Posted September 24, 2021 Posted September 24, 2021 Call Mayer truck repair, just south of Milwaukee In racine. They can help. Not a fan of Milwaukees truck country. There are some hose shops that can make 1 uo for you In racine as well. Ryan 1
vito.a Posted September 24, 2021 Posted September 24, 2021 Any good hydraulic shop can make a new hose. Even our larger NAPA store makes them. The only problem with this is you have to take the original off and take it in for them to duplicate. And yes, you do not have a Freightliner chassis. Monaco built their own Roadmaster chassis at the Oregon plant. Much better than a Freightliner.
throgmartin Posted September 25, 2021 Posted September 25, 2021 We use a mobile hydraulic guy who comes to our shop and makes the hose on site for our customers coaches. He removes the hoses, makes new ones and installs it. He has a large truck with a portable shop in the back and does all his hose making there. Very convenient and his rates are not bad. Saves us having to remove the hose and drive to a shop then drive back to pick it up.
JSSangalli Posted September 26, 2021 Posted September 26, 2021 Any tractor or agricultural implement dealer should be able to replace it.
