ok-rver Posted October 11, 2021 Share Posted October 11, 2021 2004 HR but camera and monitor have been replaced. Camera works. Monitor shows good picture but buttons only work about 10% of the time. Monitor is WDRV-7063M surface mount, 3 camera inputs with the 4 pin screw connectors. System will self select right or left input (no cameras) and it takes multiple pushing of buttons to come up with a combination to get back to the rear camera. My system has an 4 pin adapter to get to the RCA connectors coming from the original cable run to the rear of the bus. Tim at RVCAM has told me this is a early LCD monitor because the wires connected to the monitor have a multi pin plug in connector. Later cameras were hard wired to the monitor. Hoping someone has a take off that worked that I can purchase. Live in Tulsa OK. Link to comment Share on other sites More sharing options...
jegall Posted October 11, 2021 Share Posted October 11, 2021 No help on camera , but would like to talk Holiday Ramblers. Jim Gallaway Owasso , Ok 918-284-6071 Link to comment Share on other sites More sharing options...
Scotty Hutto Posted November 23, 2021 Share Posted November 23, 2021 @Steven P - Would your setup address these issues? Also, as additional info, I replaced my factory cameras last year, and still had problems with my video (right, left, and rear). I found the culprit to be the Aladdin Jr switching. I haven’t figured out a solution, but I have figured out the video from the cameras is very clear, and the factory monitor still has a decent picture. Link to comment Share on other sites More sharing options...
Steven P Posted November 24, 2021 Share Posted November 24, 2021 @Scotty Hutto @ok-rver, I do not know if my setup would help. I replaced my Aladdin Jr Weldex monitor w a new Weldex several years ago. It too is surface mounted. I use the Aladdin joystick to cycle through it and I have 2 buttons to pan the rear camera. Link to comment Share on other sites More sharing options...
