Bjohnsonmn Posted January 7, 2022 Share Posted January 7, 2022 Hello All, While working on the renovation of our 2000 Monaco Windsor 32PB, I noticed that there was a loose wire on the ABS controller in the compartment under the driver's seat. It looks like it may be a ground, but it should be in the connector. The board side is OK, it is the wire side that needs repair. I feel comfortable remaking automotive connectors, but I don't know where to begin searching for this specific one. I've looked on DigiKey and other similar sites, and cannot narrow it down. Attached is a photo. Cheers! Brad Link to comment Share on other sites More sharing options...
klcdenver Posted January 7, 2022 Share Posted January 7, 2022 It is a molex connector. Maybe local auto parts store but for sure on Amazon and eBay Link to comment Share on other sites More sharing options...
Bjohnsonmn Posted January 7, 2022 Author Share Posted January 7, 2022 52 minutes ago, klcdenver said: It is a molex connector. Maybe local auto parts store but for sure on Amazon and eBay I figured it would be a molex, but heck if I can determine the style name and pull it up! Link to comment Share on other sites More sharing options...
cbr046 Posted January 7, 2022 Share Posted January 7, 2022 Not quite the right configuration but this might give you a start. https://www.newark.com/molex/39-01-2065/connector-housing-rcpt-6pos/dp/38C9715 - bob Link to comment Share on other sites More sharing options...
Bjohnsonmn Posted January 8, 2022 Author Share Posted January 8, 2022 Thanks for the lead cbr046! Here's where I ended up: 1-480704-0 TE Connectivity AMP Connectors | Connectors, Interconnects | DigiKey Along with the pins, 350218-1 TE Connectivity AMP Connectors | Connectors, Interconnects | DigiKey And 2 of these per plug: 350812-1 TE Connectivity AMP Connectors | Connectors, Interconnects | DigiKey The strain relief is different, and actually made for a bundled wire rather than the multiple wires that come into the plug. Even calling in did not yield the exact replacement. It does look like it will work! I'll report back here if it does so others who run into this have a resolution. Cheers, Brad Link to comment Share on other sites More sharing options...
pwhittle Posted January 8, 2022 Share Posted January 8, 2022 Mouser shows the connector in stock https://www.mouser.com/ProductDetail/TE-Connectivity-AMP/1-480704-0?qs=sGAEpiMZZMsyYdr3R27aVxI08ncWuDZS Link to comment Share on other sites More sharing options...
dl_racing427 Posted January 8, 2022 Share Posted January 8, 2022 For future reference, here's a group dedicated to identifying and sourcing automotive connectors. Geared more towards major auto manufacturers, but could also be useful for RV's. I've found stuff I needed for my race car on there. https://www.facebook.com/groups/4359499570789592 1 Link to comment Share on other sites More sharing options...
